Why can't it be done
Yeah, but: from experience, most of us don't look at the gauges until we know there's a problem, usually because a fault indication light comes on. The impeller on my XK8's water pump failed, but I didn't notice until the red warning light came on. The gauge was reading pretty high by then, but I hadn't noticed - concentrating on speed & other traffic, as you tend to on a motorway.
Weirdly, the 5.0 manual makes no reference to an oil pressure sensor, so I don't think it has one. Instead, there are other systems which rely on oil pressure, particularly the variable valve timing, which will give alerts if the pressure is too low.
Yeah that's to bad but if there were such a thing you could mount a sensor in the same hole that would read oil pressure and still mount the low OP sensor. I don't even know yet what the normal running OP is supposed to be . Does anyone know as I would think it would be around 45psi at around 2000 rpm and maybe 60 psi at 4-5K.
Some people make sure the gauges are mounted as part of a scan line. Side mirror, gauges, rear view mirror. The eyes are always moving. A further enhancement is to rotate the gauge body such that "normal" is at top dead center. Very fast to work with.
The safest driver I have ever seen was a priest turned coach driver. His eyes were always moving.
Alarm lights have their uses ... so long as the alarm thresholds are useful. 7'ish psi is not terribly useful. Instead I have purchased a 15/30 psi pressure switch. Turns off at 30 psi rising turns on at 15 psi dropping.
Exactly! An ELM327 and a smart phone with Torque Pro. Done!
The following 2 users liked this post by Big Otter:
SoCal Babe (05-15-2014),
tberg (05-15-2014)
Im very annoyed by this as well, pparticularly because I want to do some extensive modding to my '10 XKR. I think im going to go with the Zeitronix and pretty much every sensor they offer. Just havent decided on going with the lcd, the dashpaq, or just a small laptop to display the info I want. Ideally a laptop with a video out somehow hacked into the headunit would be an amazing way to do it!
What does work is a turbo oil hose kit for certain turbos using that thread. The tee block at the remote end has 1/8 NPT thread which is quite common. The engine end has the correct thread on the included banjo bolt.
The original oil pressure switch is also normally open as opposed to normally closed. Therefore some circuit work is required.
There is also an additional original oil system sensor on some Jaguar engines that you might be interested in observing. It is an analog oil temperature sender mounted next to the oil pressure switch. The factory wiring ties it to the ECU.
CleverName (05-15-2014)
#28
there is a kit
OK I'm beating a dead horse here but I am a little gauge ****. We took a nice little 3 hour drive the other day through the NY/CT countryside and I noticed I kept hunting for the gauges like oil pressure and water temperature and voltage. As mentioned before with all of my other fun cars this was an area which you had to keep an eye on and now I'm trying to ween myself of this habit. So with all of the technology (BT , etc.) and the ability to load up contact lists and destinations why wouldn't it be possible to hack in the ability to show a working gauge set on the nav screen and make it an option screen. Lets say 4 gauges , oil pressure , water temp. , voltage and boost pressure. I'm not a computer/SW expert (although I worked in the S/C industry) but surely someone could do it. If not I guess I'll have to go into rehab to resolve my habit. LOL ![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
1 GVIF interface to switch video inputs to the nav screen (these modules are commercially available)
2 HDMI to AV cable (AV input to GVIF interface module)
3 (wait for this
4 (this as well
Connections might be as follows:
[Car NAV unit] -- [GVIF module] -- [HDMI to AV cable] -- [Apple TV] -- [wireless AP]
All this would need to fit near the NAV unit at the back. Use mirroring function on the iPhone to display whatever is on the iPhone onto the car console display.
Of course, the above is just conceptual
#30
Be pre-warned that mounting additional senders is very awkward. Jaguar uses a an odd ball thread. M10x1.25 face seal. Sometimes found in brake lines, but not as a face seal type.
#31
#32
The problem with swapping any modules in the XK is that you need access to the Jag diagnostic tool to authenticate them, otherwise the rest of the modules won't recognise it. And the instrument cluster isn't just a display, it's also a sort of central clearing house for a load of sensors. So it's possible you'd have trouble getting the GT-spec software in it to play nicely with non-GT modules.
Things used to be so much easier in the old days...
bigdhenderson (05-15-2014)
#33
I don't believe that one can compare an automobile that was built in the 1960's or 70's or even 80's to a modern technological car like a 2012 Jaguar XKR, whether it's a Ferrari or any other car. Yes, these types of year models were basic and added basic gauges. It was easy to watch the gauges. It would be beyond my personal belief that Jaguar would eliminate any sort of alert to a driver/owner for low oil pressure. Just because a driver can't see an oil gauge doesn't mean there is no alert povided.
I suggest that you consider contacting the local Jaguar techs to get their thoughts on your issue. Trying to add gauges, sensors, video screens, etc, seems a worthless cause, when more investigation, research and due diligence is required to seek and secure the correct facts of what Jaguar does or does not provide to meet your worries. It has already been posted and noted that Jaguar does not provide true oil pressure to the driver, but I am certain other technologies built within the car systems will alert the driver.
It sounds like poster "Big Otter" has found a resolve (ELM327 bluetooth OBDII reader with the Torque Pro app loaded on smart phone or tablet) to supply drivers with some solid basic data on the Jaguar XKR. For a small investment of the OBDII device ($20.00 to $40.00) it might be well worth you consider doing this. However, you may have to throw away your old style "outdated" flip phone for the new technology of a "smart phone".
Big Otter (05-15-2014)
#34
Here is a real-world example of what the ELM327 OBDII adapter + Torque Pro smartphone app looks like from the driver's seat.
In this example, revs, speed, coolant temp, air temp, intake temp and volts can be seen. There are many other sensors that can be monitored. You can even see any fault codes that are issued and clear them if you wish. You can have many sensors displayed, or just one big one. You can vary the colors via "themes."
My Samsung Charge uses the Android OS and the mount is made for it. There is probably a dedicated phone mount for your phone too.
The ELM327 is <$10 and the app is too, if I recall correctly.
Please let me know if you have any questions.
The following 3 users liked this post by Big Otter:
#35
OMG!! This thread reminds me of my first boyfriend
All I wanted from him was to f*** me silly
All he kept worrying about was the rubber breaking
i got rid of the first boyfriend and got me another that rode me into infinity and beyond
For all the guys that are worried about your cars: SELL THEM!!
All the others: Hammer your cars like you were on top of an 18 year old blue eyed blond
The following 3 users liked this post by SoCal Babe:
#36
You're one "wild" woman.
#37
Jaguar is a major automobile manufactuer. They employee a multitude of highly qualified automobile electrical and mechanical engineers of all types and Jaguar spends millions of dollars to design their cars and brand. I am quite sure that they have worked out all isues in regards to notifing the driver/owner that there may be a oil pressure problem. There is no evidence (oil pressure switch triggers at something like 7psi) provided that the Jaguar XK/XKR oil pressure warning alert goes off when the oil pressure drops to as low at 7 PSI. If so, document the evidence so we may all see and evaluate.
#38
#39
And SoCal, this is about monitoring performance: Boost, Intercooler temps, AFR, etc....not just worrying about breakdowns.
#40
