Why do I have to use key slot
CR2032 battery life varies greatly depending on how long it sat on the shelf before you bought it, the manufacturer, and how often it's used. I recommend that you never buy them online because you have no way of knowing if it's genuine or a cheap Chinese knock-off and you can't verify the date code. I always buy a 2-pack of brand name CR2032 batteries at a local chain drug store so I can check the date code. Changing the battery is easy and no programming is needed. Keep the other one in your glove box as a spare for when you get the dashboard warning that your keyfob battery is low.
The rear of the Smartkey case wasn't applying firm pressure on the battery with the early models and was subsequently redesigned. Assuming you use premium CR2032 batteries, a new case could get over this issue.
I fitted new cases to the remotes on my 2007 XK when I found out they were only about one tenth the cost of a new remote. If you do this, use only OE Jaguar - there's some Chinese rubbish listed on ebay etc.
I don't know about all THAT...
I've replaced the batteries in my smart key one time, about three years after I purchased it. THAT was from a Lease Return, and I assume it had fresh batteries installed prior to the sale. I did get one new remote when I thought a grand kid lost one, but later found it under the PAX seat.
The current battery is probably two years old now, the one that was originally in the new key I got from Jaguar. The other two keys still have the ones from three years ago, and both still work.
Maybe I'm just lucky? I have had OTHER batteries in remotes go bad quick. My F150 specifically, I need to change THAT one twice a year.
Ranchero50 (04-04-2019)
Cee Jay (04-04-2019)
carzaddict
04-21-2023 07:28 AM
