Will 2008 XJR cremona wheels fit a 2008 XKR
Old 07-23-2012, 05:32 PM
Chromey35's Avatar
Default Will 2008 XJR cremona wheels fit a 2008 XKR
Hello does anyone know if the 2008 XJR cremona wheels will fit a 2008 xkr thanks for any info. Even if spacers have to be used not a problem.
Old 03-20-2013, 03:08 AM
milleniumaire's Avatar
Hi, just wondered if you ever got your Cremona wheels as I'm also looking for some for my 2007 XKR.
I'm aware that they were put on the Portfolio XKR and the XJ, but like you, not sure if they're the same fitting.
Old 03-20-2013, 03:37 AM
Received 4,457 Likes on 2,427 Posts
The bolt pattern is the same, but that's about it.
XJ Cremona's are all 20x9 with ET49
XK Cremona's are 20x8.5 fronts ET46, 20x9.5 rears ET35
Will probably fit, you would need spacers on the rear.
Old 03-20-2013, 02:13 PM
Okay, thanks for the info.
As it happens, I called a few Jaguar dealers today and found that I can get a set of 4 for my XKR for just over £1,900, which includes a 20% discount.
I now have to decide if I like the Cremonas that much more than the Senta's that I already have!
toronadomike
08-07-2022 03:41 PM
prettydaim
03-28-2021 07:47 AM
Beardy
09-18-2015 10:00 AM
tberg
09-07-2015 07:32 AM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Will 2008 XJR cremona wheels fit a 2008 XKR
