After closer examination the Svr are 11" rear with a 54et whilst the gyrodyne are 10.5" rear with a 38et looks like you'll need a 20mm spacer to make things right
The 10.5" goes on without any issue so I don't see a issue with a further increase of half a inch however due to the different offset your definitely going to need the spacers to push the wheels out on rear for clearance
Hello, I just purchased a 2008 Jaguar XK. The wheels on the vehicle are curbed really bad and are also peeling. I found some wheels off of a F type Jaguar and wanted to know if the wheels would fit. The offset for the front seems to be pretty close to what I have now but the rear is et27. Does anyone if these wheels would fit? Thanks in advance, I’m also attaching a pic of my vehicle and a pic of the wheels I am thinking about purchasing.
