Will XK h&r springs fit the XKR ?
I suspect that they do but, I would recommend talking to the manufacturer before you buy. Make sure that you are getting the spring rates that you are looking for, be that primarily for ride comfort or stiffer track-style. Also, do dig around both Mina and H&R website as I seem to remember reading the claim from Mina that their spring rates were close enough to the OEM ones where no damper replacement would be needed. At the same time, if my memory is correct, the H&R website claimed that dampers do needed to be replaced with their stiffer springs. Needless to say, the cost differences of damper replacement vs. not alone could make you decide. If you do decide to replace the dampers make sure you know that you may be giving up the OEM electronic damper controls that, IMO, work darn well. Albert
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
Tar
09-06-2015 11:24 AM
