Wind Noise in Hatchback
I could not find a post about the ability to hear the outside from the hatchback area. I am missing the little privacy screen but I am sure that can't be what absorbs that much sound. I also went over the rubber and it all looks plump and intact. Is this amount of wind and exhaust noise normal?
Chris N (09-07-2020)
Ditto Barnsie...
- Another tip: Cut yourself some strips of paper, and place these across the hatch weatherstrip. Close the lid, and pull each one out. As you do this around the entire opening, you will quickly find the area(s) that aren't sealing.
- If these areas are adjacent to latch (eg, bottom horizontal); check striker adjustment
Hope this helps!
Hope this helps!
When cruising at higher speeds, most of the noise I hear is road and exhaust noise and it mainly comes from the rear. Is is not a lot but it is there. It doesn't sound like a poor seal. I put it down to the aluminium construction transmitting more sound than I would have expected. Maybe I should take a look too ...
barnsie (09-08-2020)
Elizabeth Blake
09-17-2019 08:12 PM
