Window Control Switch/grab handle cover
Since you are trying to remove a cover, and not the grab bar itself, you could try getting a trim removal tool under the cover (between the cover and the main part of the bar) to pry it off. I'd try from the bottom side first.
Haven't looked at the handle closely, so I didn't know there was a cover on there.
hafren (12-13-2017)
Yep been able to remove door panel in one piece but can't remove the window switch so looking at the manual its says to remove the grab bar but its proving very obstinate .
Yes, I believe it must have been redesigned after the manual was written because the are 3 screws buried inside the door card that must be removed in order to get the cover off, I know because I did mine so I could get rid of the horrible leather wrap.
