Window in the Convertible top
#181
Rear window
I just had my rear window re-glued by a local top shop. He used a window glazing adhesive, and added a little bead that is outwardly visible but he says will improve the adhesion. You have to look for it to see it. We'll see how it holds up. BTW, he quoted $2200 for a new top excluding a new headliner. The top is 11 years old and showing wear so I'll probably replace in a couple of years.
#184
Stuart, I miss quoted the price and I apologize. The total came to just $2,000 not $1,800 I had remembered. Still they did a great job and turned it around in just a couple of days. I did a lot of research trying to find someone reputable in my area (extreme NE GA) and settled on Tim's Auto Upholstery in Gainesville. I also had them do the interior matching leather cover for my rear seat tonneau too. That is the satellite shop where the home shop is in Duluth.
They advised me to let the top sit in the sun for a day or so, to allow the fabric relax in to place, but this photo was taken before that so it looks much better now.
Stuart S (08-24-2018)
#186
Rhino Glue to the rescue...
Finally getting around to posting pictures of my recent convertible top rear window fix. Got the Rhino glue - pretty good stuff, there. Got the Suck-N-Clamps. Reminds me of a line from the Wayne's World movie, "It sucks as it clamps" Good advice from both Stewart and kj07xk to leave the part of the glass that's still attached attached. I did, and it turned out to be the way to go. As you can see 3/4 of the window was pulled away, everything except for most of the top edge and a very small bit of a thread in the middle of the bottom.
So, I started from that thread in the middle of the bottom. Tape certainly helps you to not make a mess. I left the old glue on the window and used it as a guide to put the blue masking tape on. Just put the edge of the masking tape right up against the edge of the old glue. Perfect guide. Then with a razor scraper you can carefully scrape off the old glue, taking care not to cut the tape, leaving you a nice edge to glue up to. Everything about this job comes down to patience. Don't try to rush anything. Take your time. Be patient. Measure twice, glue once.
Here's a shot of the blue tape up against the old glue:
I opened the top partially, until the rear part came up about 6 inches or so, so I could get my hand under there and push up on the window glass. You'll need to support it with something or it will drop back down after a few minutes. I just used a wood block.
Also, there's an inside headliner that attaches to the top with that plastic, nubby kind of velcro stuff. You can see it in this picture. That was all pulled away from the top, and that's good. Leave it unattached and out of your way. Last thing you'll do is snap that back in place.
Here we go! First clamp in place. Like I said, there was a tiny bit in the center of the bottom still attached, and that seemed like the best place to start. I used the white masking tape on the fabric to keep from slopping glue on it. Also, a little piece of double-stick tape on the bottom of the Rhino glue stuck it to the window and make it a lot easier to handle, especially when you're trying to juggle the clamp, the window, the top, a beer...
Then, it's just a matter of working outward from there. I put a cardboard box in the car to hold up the glass. That worked pretty well to take the stress off the area where I was trying to get it to line up properly. Here's with 2 clamps -
And here's with 4 of the clamps in position.
I used popsicle sticks to spread out the clamping instead of the paint stirrer. I guess either one will work well. The shorter sticks let me work on a smaller area at a time. The big "C" clamp worked well, too, but you can only use it on the bottom edge where it's close enough for the clamp to reach. When you get to the outside edges of the window, space gets tight and you just have to do what you can, wait for the glue to set, then move on. While waiting, I started heading in the other direction...
With the middle pretty well set, I could re-position some clamps to the ends.
You can use the clamps either way, and sometimes using the butt end to hold the glued area works better, spreads out the clamping, and allows the other end to fit in the crowded space. Finishing up:
All in all, I'm like 95% happy with the job. I think I could have pulled the sides in a little tighter, because there's a bit of a loose area on each side. Trouble is, it was hard to do that without bunching up the edge somewhat, so I had to make sure that would lay down flat. If I had to do it again, I'd probably stop about half way through, let the glue set well, then close the top to see how it looked fully closed. That may avoid the problem. You can see it better on the second picture, it shows the red edge which I think is part of the rear window defogger.
All in all though, I'm happy with the job. Sure beats laying out 2 grand for a top. The upper right section wasn't done, and from all accounts it's just a matter of time before it lets go, so maybe when that happens I'll see what I can do to adjust the sides a little tighter. Thanks to everyone who provided insight and advice!
The following 2 users liked this post by fritzthecat:
IowaPopPop (08-31-2022),
Jonesjag (06-18-2022)
#187
#188
Thanks for the info. My 2007 XK top came loose and after gluing the top all appeared to be okay. Drove it a couple of times and top held in place. A couple of weeks later I moved the car out of the garage and the car set in the driveway for several hours. When I got ready to move the car back into the garage, the glue had failed and the window was again sagging down. Obviously, the hot Texas sun is too much for the glue to hold. Think I'm giving up the glue bit and buying a new GAHH top. Spoke to a recommended custom detail shop and they will install for $550. My total price is to be $2400. ($1850 - top; $550 - labor)
Regards,
Regards,
#190
Looks very good. Hope I never have to deal with it, but nice to know there is an alternative besides changing the top.
My BMW with the plastic sewn-in window there was no alternative. Although OEM was zippered in, but typically the window cost as much as a new top, plus the top was usually worn out also, so a new top was the best solution.
#191
Good luck with your repair. I suggest repairing only the small section that separated, and inspect the top daily for more separations. It will separate more; it's only a matter of time. It's easier to repair a small section at a time and you'll get a better, more uniform bond. Use a small knife to scrape the old, dry glue - you don't have to remove it, but roughening it up provides more surface area for better adhesion. Make sure you apply even pressure with the Suck-N-Clamps; otherwise the repair will have ripples. If you use too much glue, it dries clear and the excess can be removed with a razor blade scraper and some Windex or other glass cleaner. Just take your time. You won't have a concourse top, but its life should be extended for several years.
#192
My window has now fully detached in some spots and you can stick your hand through the gap to the inside. I have ordered the Rhino Glue and the Suck n' Clamps, and anticipate doing this job in many smaller (4"?) sections. As I do not have a garage, I may need to do this in my office garage over the course of several days. My question is, how long does it take for the Rhino glue to dry/set up before I can drive the car again? It appears I can do the entire repair from outside the car with the top completely closed, which is a plus.
#193
Thanks to all of the guys who have posted their CVT separation issues and to a pioneer in this effort "Stuart S." My time "In the barrel" will come too, I suppose.
Can we assume much of this separation of the window be attributed to sun and heat? Or, simply an aging process together with poor design?
#195
Ya know, I've used Rhino Glue before for a bunch of 'stuff', but I've never in my entire life been more impressed with the absolute holding power of ANYTHING than I was with Loctite Landscape Adhesive. It remains 'semi' flexible, and will NOT come off ANYTHING.
If it comes to a point where I need to glue my window back in, I will most probably use it then.
SuperTrav (04-15-2019)
#196
I contacted two dealers
The first , Wilde in Sarasota, originally stated they just would just replace the top for $3700+ . When I asked about the TSB they said they knew about it ( although they did not list that as an option originally) but that no car has come in that met the 350mm limitation.
As I knew my car had a 6-8 inch separation, I went out only to discover the window was almost completely detached. It was just holding on at the very bottom
I was assuming that the bouncing action when driving was partly the cause, not sitting under a cover
The second dealer I called said they didnt do those types of repairs and gave me teh number of two repair shops. He recommended googling 'Auto Interiors'
I called one of his recommendations and they also stated they just replace the top ( the other was quite a ways away)
I eventually found a repair shop , on google, and just picked it up. 300 + tax , he ran a stitch around the window , holding the fabric together and re-glued it. It looks great, I'm just hoping it holds up. ( he was also no warranty)
He also said, in Florida, its a very common problem
Sorry, I didnt see the request about pictures until after I dropped it off
Mine started as a small hole or separation in the upper left corner and was pretty stable for a while , I noticed it when it was about 4-5 inches long and it was pretty stable for a while. When I looked last, the window was almost completely unglued, along the top and down both sides
RalfBrookes@gmail.com
(239) 910-5464 (cell/text message)
#197
Sarasota Repair Shop - name?
I would like to pursue this option - what was name of the repair shop in Sarasota that did the stitch and reglue and did it work well and hold up over time?
text (239)910-5464
text (239)910-5464
