Window in the Convertible top
#301
She didn't say which glue or method she used to do the repair. This thread discusses several different adhesives and methods. She said that she's doing the repair in this thread, but didn't go into any details. We need more information to help her, with photos.
I agree with you, Ken, because I experienced no bleed-through or color change with Rhino Glue. My repair is still holding up Mineine, but I haven't driven much due to CV and my XKR is now a Garage Queen.
#302
What's on the left corner of your top? If it's a weight, that's a mistake and you should have used the clamps. You should have applied Rhino Glue one section at a time because it dries quickly.
As for your leather dashboard, see:
https://www.jaguarforums.com/forum/x...rating-233590/
#303
Supplies
#304
On 11-20-2020, you thanked me for giving you advice on how to do this repair. If you had followed my detailed DIY instructions, you wouldn't have the problems you're now dealing with. Sorry, but I can't help you with what you've already done. You should have used Rhino Glue. Good luck with your repair.
Here's a screenshot of what I previously recommended. The complete post wouldn't fit.
#305
#306
There is no Granite Crystal Grey color.
2011 Interior Colors:
2011 Exterior Colors:
The sealant you used is made to repair tents, a fabric-to-fabric bond. Time will tell how long it bonds with the glass rear window.
- Caramel w/Softgrain Leather Seat Trim [Tan]
- Ivory/Oyster w/Softgrain Leather Seat Trim [Off-white]
- Warm Charcoal w/Softgrain Leather Seat Trim [Gray]
- Botanical Green [Green]
- Cashmere [Beige]
- Caviar [Black]
- Claret [Red]
- Crystal Blue [Blue]
- Ebony [Black]
- Frost Blue [Blue]
- Indigo Blue [Blue]
- Liquid Silver [Silver]
- Lunar Gray [Gray]
- Polaris White [White]
- Spectrum Blue [Blue]
- Stratus Gray [Gray]
- Ultimate Black [Black]
- Vapour Gray [Gray]
Savitt1 (01-23-2021)
#307
All,
Just wanted to add my datapoint as of today. I just picked the car up from getting a new top. We went with Gahh top and reused the headliner. The Gahh has a lifetime window warranty. It was ~$2300 installed.
We tried the solutions offered here and it bought me a year before I had to do the top. I think mine may have been worse than others as there was just no fabric to install to adhere the window too. I was also still getting leaks, so I had to replace it.
best of luck!
best of luck!
Savitt1 (01-20-2021)
#309
So far all is good
After my fix I have had no issues. Have tested it several times with directly running hose all over the edges of the window roof connection. I put the top down at least daily living in sunny Florida.
for back up tho i did locate a top off eBay for $900. Have yet to secure a person or business to install it but it also isn’t needed just yet. I’m glad for the forum and the direction of everyone here. I found the rhino glue to leave a white thick and obvious haze on the edges of my roof so I opted for the above. Again maybe not the right thing in all viewpoints but thinking this was a suggestion I didn’t realize the aftermath i would get. So sorry to I guess challenge the group. After all your much more of experts than I am or will ever be. But granted my way has worked so far, I take that as a win ... at least at this time. Always have a back up thanks and happy manic Monday.
#311
Sad but expected. Need tampa professional to fix
Stuart, thanks for sniffing out this fix, I owe you an adult beverage if you are ever in Tampa. My window dropped out at the top and both sides 5 or 6 weeks back, local shop quoted $400 but I decided to fix it myself. Easy and straightforward with your instructions and all the other contributions in this thread. Weather has been great the last month so fixing wasn't a big priority, I found two rolled up towels shoved behind the rear headrests kept the window in position and the car driveable. Now that it has started raining I had to make the time to get this finished.
I bought the Rhino glue and suction clamps on Amazon, wish I would have known about the clamps prior as I had a project last year they would have proved handy! I opened the top partially, turned off the car and waited for it to settle down on a 2x4, however that prop was bit too tall for what I wanted. Using a .5" fir strip instead ensured that the glass and canvas at the top were well aligned. I also propped up the window with additional towels on the back shelf to give support. That way the clamps were only necessary to create even pressure on the canvas after gluing. Out of the 6 clamps I used the first two as a holder when I aligned the canvas on the window left to right, that is the purpose in the picture below, made sure the sides and upper corners would lay flat without any buckling. That way I could start in the middle, clamp and use the paint stirrers until the glue set, then proceed down the sides.
My only regret is that I was heavy handed with the glue (wanted to make sure it took well) and it is definitely visible at the top seam. Tried to clean it up and it is better, doubt anyone else would notice but of course I see it everytime I look at the car.
Thx rhino glue was hard to work with and when it dried, it was fast to dry but ultimately didn’t last forever. It’s been approx 18 months for my fix. I’m done sweating outside tho so willing to pay to have done.
Seeing you were years ago but still maybe, can you inform at kind of shops you took it to? I’ve been to a upholstery stores to no level of success and 7-8k pricing. WTH! Definitely not going to dealer. Would anyone give feedback of if eBay should be sending money back to me or what if any issues? I found for less than $900 but I worry it’s not the same top of our caliber.
I also have lost the a moveable pane that opens when the top is put up/down. There is a slightly stretching wire/string but I can’t put it tied to anything any ideas of what it is top back panel in back driver side seat area and is it also a DIY fix or too cumbersome.? Should anyone special be used to start that repair? Anyone know how much the part is to replace? Amy and all guidance is super appreciated. Hope everyone is well and staying Covid safe.
I hope to hear from you.
take care gents (I don’t know if any female owners posting so if I am crazy with my decisions questions etc, blame it on that tidbit I tried. And now I didn’t lol.
Not great pic. Dismal day and shadows.
Showing the water damage now in headliner. Made me so sad as I saw while driving and pouring rain. So day was worse and worse. Any guides me will help. Thanks
Alina
#312
See Post #94 Tampa FL replacement tops:
https://www.jaguarforums.com/forum/x...-113105/page5/
See Post #7, Moving Flap Kit:
https://www.jaguarforums.com/forum/x...ap-kit-249643/
I'm confused. You just said that you used Rhino Glue, but in your Post #303, above, you said that you used this tent fabric repair product "FCSS".
Post #303
Your repair should still be holding if you had used Rhino Glue and followed the instructions. If you used Rhino Glue on top of FCSS, that's why your repair failed. You should have completely scraped off the FCSS before using Rhino Glue. If FCSS was the only adhesive you used, that's why it didn't hold up.
Once the window begins to fail, simply repairing the loose section is not enough because the rest of the glass will continue to separate from the fabric. All that original adhesive will eventually fail, and all of the glass will eventually need to be reglued as the original adhesive continues to fail.
Post #303
#313
Since I did the repair myself using Rhino Glue and it has held for the last 2+ years I don't have any direct recommendations for a shop. However, the guy that opened this whole discussion used a place in St. Pete, on Haines Road, called Top of the Line Interiors for his top. They are pretty well reviewed on Google for what it is worth. But I have never used them for anything so cannot vouch for them.
That is all the direction I can give you at this time.
Mark.
Here is the previous dialog regarding the shop in St. Pete:
6777 Haines Rd N, St. Petersburg, FL 33702
#314
In a separate thread, Savitt1 explained why her repair failed. She stated "thanks Stuart S. I did rhino glue with tent repair compound on top so there’s the reason why as you said." See her Post #95 here:
Using a different adhesive on top of Rhino Glue won't work.
#315
Well... my turn. Had to happen eventually, I suppose.
Hurdle #1: there has apparently been a run on the Suck-n-Clamps nationwide. I blame Stuart. Any leads? The Amazon link on this thread seems only to sell a 12-pack, and Walmart is out of them...
https://www.walmart.com/ip/CRL-SC6-S...Pack/225604200
EDIT: found them here:
https://www.dkhardware.com/suck-n-cl...uct-26093.html
And here, on Amazon, but this seems to ship from overseas:
#316
Also, I read through the posts, and I have a probably stupid question about the actual application of the glue, since I've not had had good luck, long-term, with super-glues:
I find one part of the Rhino Glue instructions unclear (beyond the "less is better" advice): how best to apply? It this a one-side-only coating, or both sides? A few seconds to set, or this is more a case of laying down a quick bead to one side (along the glass, I'd assume) and clamping immediately? And is using too much really that bad? I'd really worry about not using enough.
Thanks as always...
Thanks as always...
#317
PK, it doesn't take much at all, I like others applied to the glass only and have had no issue. You will need to clean up the edge as it will have old adhesive residue.
Rhino comes out as a liquid, not a gel, so it spreads pretty well. If you go the route of too much make sure you get the excess up after applying pressure while wet. Once that stuff dries it is like concrete. I did mine in manageable stretches, the first one I put down I let it dry with the seepage and it was rough getting rid of that, trying to cut away the gunked adhesive along the cloth line of the top with a razor blade took forever and I had some moments where blade and cloth made contact which was no good. Seriously, that area I allowed the excess to dry was my nemesis for a while, really made me mad that I had done that. You can use tape to mask the glass but make sure you pull the tape away before it dries or you end up with a small tape line glued to your window. Again from my first line of gluing
It starts to set quickly, didn't time it as I put the line down and clamped it in position. Did this in a couple of minutes so can't tell you just how long you have to fuss with positioning.
pk4144 (09-07-2021)
#318
#319
10mos. UPDATE
Hi,
Time for an update on my window re-glue, utilizing the Stuart S "Rhino procedure". (see my orig. Posts 289 & 291). Outcome:
10 mos. Later, it's still holding fast.
Background:
Living in the N/E, I use the Convertible sparingly, and only in beautiful weather. I have a 3-Season XK, which affords me that luxury. Bottom-line, the Convertible is a fair weather fun-car only. Therefore, testing is limited, and never in harsh conditions. So far, the window repair has been solid;
up/down and in between. (again, car is sparingly used.).
What I did:
I followed the accepted procedure, outlined in previous posts: I utilized a thin layer of Rhino, with multiple suck-clamps closely spaced. I also used a number of wooden paint stirs, for even pressure. Bunched up towels & pillow throws, were placed inside veh.at window site, propping it up internally, to stabilize during clamping/glue curing.
The glass seperated from it's canvas Top in 2 locations: the entire lower edge, & 2/3's up one side. Work was done during Fall, in an unheated garage. Since the vehicle was being put to bed 'til Spring, I decided to maintain Clamping for an extended period; much longer than suggested. I kept it clamped for10 days, with a space heater aimed toward the site in 12hr intervals, for the first 3 days.
The only other deviation to suggested practices was my decision to not remove the in-place product remant of a failed past gluing (possibly, as Stuart S suggests, a popular 3M product. - see his post #290).
I decide not to remove, because it was rock-hard solid, and near impervious to chipping. it was also scored with fine lines where the weave of the canvas top had previously embedded . I Thought that this scoring would give me a rough enough base to aid in bonding. The fact that the Rhinon Glue touts itself as a "product that will bond with anything", gave me the final impetuous to try this unorthodox move. It's held til now....so far, so good.
Background:
What I did:
#320
Lifetime Warranty on Top Replacement is now 5 years
It's good to see that the glue fix is working for some people. In 2015 I had a shop glue the glass back in but they wouldn't guarantee it would hold. It didn't, failed within a few days. So I had the top replaced for about $1,325 including installation. The new top lasted about 5 years. I do keep the car parked outside and it is hit by the brutal Southern California sun every day of the year. So not surprising that the glue would fail eventually even on a brand new top. I was resigning myself to buying a new top and having it replaced. Prices had gone up significantly since then. It's about $1,500 for a new top now (was about $600 back then...aftermarket...not Jaguar stock!)
I spoke to a local Auto Upholstery shop in LA and they were gonna replace the top for about $1,850 installation included. I was about to get the job done and did put a $500 deposit while we waited for the top to be delivered. That's when I decided to track back to my purchase in 2015. The shop who did the replacement was now out of business. But I was able to find out that the new top back then probably came from Robbins or GAHH. Apparently these two companies are somehow related to each other. One guy said that's our sister company about the other. So I went to GAHH to ask about the warranty on my top. Looks like Batz Auto Upholstery did indeed purchase my top from them 9/29/15. I saw the data I had input on driverside.com. They’re gonna replace the top because the rear glass had a lifetime warranty at the time of purchase. They now only give a 5 year warranty on that. So GAHH is gonna send the new top to Reyes Auto Upholstery off Alameda and they need to ship back the old top. Install cost will be $650 and comes out of my own pocket. New top was gonna cost me about $1,200. Thank you lifetime warranty. Typical though that they're not offering lifetime warranty on this top anymore. :-(
