windscreen keeps falling down
Hi Stuart,
Sorry for the late reply. Had the cat stored so went over for photos (attached).
- I think it's the original
- I don't see adjustments for springs
- I would say 7 years
- It does have the spring loaded fastener. However when I push in one side I believe the other side spring pops back.
Hi Michael,
It appears that you have the OEM Jaguar windscreen, as the side clamp mechanism of my aftermarket Adamesh windscreen is not the same as yours.
My side clamp:
Nevertheless, although they're different designs, I think they both work the same way with spring tension holding a retractable pin in the hole on each side to support the front of the windscreen and stationary pins that fit in the rear seat back to support the rear of the windscreen.
From what you explained, I think one of your front retractable pins is not fully engaging into the hole. You may want to see if that's the case and, if so, if there is anything blocking that hole or causing the pin to bind and not extend fully into that hole.
For details of my installation, see my posts ##2 and 4 in this thread: https://www.jaguarforums.com/forum/x...flector-62273/
Hope this helps,
Stuart
P.S. In your last picture, it appears that the pin is in the retracted position, and not pushed into the hole, which would explain why your windscreen keeps falling down. I don't see how the pin on one side could be connected to the pin on the other side. Make sure that you have the pin in the front of the windscreen properly aligned with the hole in the side of the rear seat panel so that the pin fits all the way into that hole.
My side clamp:
Hope this helps,
Stuart
Michaell (07-26-2017)
Received 2,058 Likes
Went back to reread your post and Stuart's comments, and yes, your picture shows a side pin that's not fully engaged. It can be tricky to get them both to engage when putting in the screen.
Also, and maybe its just the angle of the picture, it looks like that center bar (between the two pins, in the middle of the screen), is slightly bent. That might contribute to your difficulty in installing the screen, as the pins aren't going straight into their holes.
If you look at my side pins, they are fully engaged. These do not have any spring tension, but they do 'click lock' when fully deployed (the click lock for the pin is in the windscreen itself, not the socket.
The windscreen also click locks into the open position, which is slightly forward of vertical.
My center bar has a slight curve to it too, probably the fabric tension.
Driver's side pin, fully engaged and click locked.
Passenger side pin, fully engaged and click locked.
Now that it appears you are on the road to repair, I can't resist:
Told my doctor one day that it hurt to lift weights over my head. He said, "quit lifting weights over your head!"
Good luck on your repair. If it get too bad, the Adamesh is a good quality product at a reasonable price.
