Windscreen Washer fault
Received 1,975 Likes
If you're absolutely sure that there are no obstructions in the line, it's got to be the pump. Making noise, but not functioning.
When I got my XKR some 4 years ago, the pump would not pick up water. Lines and nozzles were all fine. Located problem to washer tank - lack of use and somehow there was a sediment blocking the output from the tank. Removed line from wipers (from the T connection if I recall correctly as the connection is some form of valve) and blew into the washer tank. Problem sorted.
hawaiianjag
03-17-2016 05:58 PM
ejjbee
03-17-2016 10:24 AM
