Windscreen washer fluid leak
You'll be unlucky if the reservoir has cracked. It's worth checking for a leaking seal before assuming the worst:
![Windscreen washer fluid leak-screenwash.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/145334d1491813244t-windscreen-washer-fluid-leak-screenwash.jpg)
There's a seal on filler tube to reservoir (item 9), one on the screenwash pump (item 3) and another on the headlamp wash pump (item 5). There's also a grommet on the fluid level sensor (item 7).
michaels2411 (04-10-2017)
That's the spirit, out of the ashes rises the Phoenix!
I wish there was a Quaife for my model, I even went so far as to contact a custom diff builder who makes LSD units for BMW's. He is too busy to take on a new brand as his business is booming with the new generation BMW's and getting those owners into superior hook-up at launch.
