Windsheild washer not working
if you get the workshop manual, its clearly explained in there.. think the manual would not be soooo expensive..
Its actually on the Right Front - under the RH Splash Shield
So you 'd need to jack your car, remove the wheel, remove the Fender Splash Shield
Then you will see to motors, the high-pressure headlights (optional) and the washer pump (84.10.21)
The washer pump is the smallest of the two..
(PS> Make sure you support the vehicle with enough stands, only a jack would be dangerous)
al_roethlisberger
09-11-2015 10:04 PM
philwarner
09-05-2015 10:05 AM
