Windshield fog
Windshield fog
2012 XKR Has anyone had issues with the windshield fogging up in the morning?
It took the windshield over 15 minutes to defog this morning. I had to drive down the road after the 15 minutes and the defogger finally started blowing on the windshield after a half mile down the road. The defogger doesn't seem to kick in until I've going down the road awhile, but that's useless because I need to see through the windshield to drive down the road. I'm going to complain to the dealer a second time on this issue.
Seems to blow warm air then switches over to the A/C. So yours may be the same where is takes some time for the climate control sensor to determine to blow hot or cold air depending on A/C, heat. or defroster.
My 07 XKR does the same and it is my main frustration with the car. It takes 5-10 minutes for the car to realise that it actually isn't that cold and reduce the heat output. I have tried changing the interior temperature sensor but it has made no difference. My X350 was much better at regulating the temperature.
At least it is summer here now so I tend to drive with the windows down
My XKR doesn't have these problems, but I also park in a covered semi-underground parking spot, so I don't get any fog or frost.
If the air in the car is warm when you park it and the glass becomes cold as the sun goes down, depending on the dew point, you will get fog on the inside of your windshield. This will take a long time to go away because as you said, the car's engine needs to warm up to put heat out of the defogger vents. That's how it is on every car. You could always manually override the fan speed and turn it way up but that probably won't help much. Complaining to the dealer won't solve anything and will just result in being without the car for a few days!
BTW I just had the exact same thing happen to me on my $1200 winter beater Mustang, with manual HVAC/vent controls.
Update. The defogger/defroster blows on the windshield right away when outside air temp is at 54 (car parked in garage) however at 39 deg F when left outside for an hour it fogged and stayed fogged because it never blew on the windshield, so I put it up n got the F350 out.
It can also depend on how cold it is outside when this happens. I thought my X350's owner's manual said at temps below 39 degrees, the A/C compressor would automatically disengage itself, thus providing no "drying" effect.
Absent the compressor drying the air, you are left with using plain old heat. How cold was it this morning?
Not sure if the 39º is actually a factor, I can't find anything in my XK manual about a minimum temperature for the A/C compressor to operate (I swear it said something for my '06 XJ)
This is what my manual says about the demister (may be different for your 2012):
To remove frost or
heavy misting from the
windscreen, press the
DEF button.
• The blower switches on at a high speed but
it can be adjusted manually if required.
• Air conditioning switches on automatically
(to dehumidify the air) and cannot be
deselected.
• Recirculation is cancelled and cannot be
selected.
• The front screen heater and the rear screen
heater and door mirror heaters switch on
automatically, provided the engine is
running.
• The button indicator illuminates.
Press again or press AUTO to deselect.
Which of these 5 things are not occurring?
To remove frost or
DEF button.
deselected.
selected.
running.
Something that confused me initially: the front (if you have it) and rear screen heaters come on automatically in cold weather.
In cold ambient conditions, at the start of a journey, the front and rear screen heaters will switch on automatically for the timed period. The rear heated screen will come on at temperatures below -1°C (30°F) and the front screen will come on below 5°C (41°F).
From the 5.0L workshop manual:
There's no mention of any difference when there is a low external temperature. That suggests your problem is a fault, not normal operation.
Programmed Defrost
When the 'DEF' button is pressed, the ATC (automatic temperature control) module instigates the programmed defrost function. When selected, the ATC module configures the system as follows:
• Automatic mode off
• Selected temperature unchanged
• Air inlet set to fresh air
• Air distribution set to windshield
• Blower speed set to level 6
• Windshield and rear screen heaters on.
I had a 98 XJ8 and now I have a 2002 S type and they both do (did) the same thing. As soon as we get in the car the windshield gets fogged. No other car I've ever owned did it this bad this fast. The defroster seems to be in sync with the A/C. Sometimes even after I get going that the windshield is clear I find myself keep pushing the A/C on and off and the defroster on and off and the fan up and down. Even that button that shows def and windshield doesn't work the way I would think it should plus the car takes forever to warm up/
I had a faulty blender valve in my XE which made the car unsafe to drive in the cold. Would ice up like crazy inside. May want to check for that. The other thing that really helps is clean inside glass. Using a squeegee with light dish washing solution will get the window perfectly clean (just like how tint shops prep the glass).
The following 2 users liked this post by mosesbotbol:
SteveLeighton (02-16-2019),
Stuart S (02-16-2019)
And the solution for this is your direct pressure sensing valve is sticking resulting in no cool, dry air hitting the windshield. Instead you are blowing moist air on it causing the fog. Change the valve and recharge the system and your problems will be over. Preaching from the owners manual about what it is supposed to do won’t solve the issue I am afraid.
The following 2 users liked this post by Mufc:
drbbop (02-19-2019),
mosesbotbol (02-19-2019)
I bought one of these for each of my cars and no more fog on the inside:
https://www.halfords.com/motoring/ca...r-dehumidifier
