Windshield and headlamp washer system
Received 1,123 Likes
Folks,
Does anyone have the mechanical/fluid diagram of the washing system?
Mine has decided to not flow to the passenger side and only dribble at the drivers side. Headlamp washing is fine.
Yes, I've checked the obvious for kinks and stoppages, but I can't seem to locate the issue... are there two pumps down there??
Thanks.
Thanks.
Here's the component location diagram:
![Windshield and headlamp washer system-xk-washers.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/64901d1480970598t-windshield-headlamp-washer-system-xk-washers.jpg)
This is the control diagram:
![Windshield and headlamp washer system-xk-washers2.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/64902d1480970598t-windshield-headlamp-washer-system-xk-washers2.jpg)
The headlamp and screen wash have separate pumps (items 10 and 11).
As your headlamp wash is OK, the screen pump is suspect. Here's the removal procedure:
![Windshield and headlamp washer system-xk-washers3.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/64903d1480970598t-windshield-headlamp-washer-system-xk-washers3.jpg)
If the pump is OK, it could be blocked screen jets. On previous models, the screen jet duckbills block restricting the flow to a trickle. The technique to clear them is to disconnect the pipe at the pump end and blow it clear with the type of aerosol compressed air can used for cleaning PC keyboards. I haven't yet had reason to examine my XK screen jets but have no reason to think they won't respond to similar treatment.
The following 4 users liked this post by GGG:
Folks,
Thanks.
Thanks.
Updating the thread with my own findings so far in case it helps others.
I disconnected the hose from the pump up to the 3-way connection that carries fluid to each washer jet and was able to blow air freely through the hose. When pressing the washer button in the car and the hose disconnected from the pump, no fluid came out although the pump could be heard running as it should. The pump locates into the hole in the tank using a combined seal and filter - short rubber tube open at the top end for the pump inlet to go into and perforated at the bottom end. Suspect either this is blocked or the pump impeller has separated from the shaft.
I've got a new seal/filter tube and will syphon the contents of the tank and remove the pump and existing seal and filter tube for inspection at the weekend.
Updating again, I syphoned out the contents of the tank into a bucket at the weekend, saw a good few blobs of black slime come out with the fluid so something must have been gathering in the tank. Sure enough on removing the pump I found the filter tube to be caked in the same black slime. I drained the rest of the fluid, changed the filter tube, reinstalled the pump, added a little fluid and connected my clear hose used for syphoning to the pump and put the open end into the bucket and tried the washers - bingo, fluid coming through no problem.
Of course I couldn't be out of the woods just yet, I connected everything back up and tried the washers again and now I get fluid from the driver's side jet, but not the one on the passenger side. Suspect there's something blocking the last section of hose from where it splits in two to go to each wiper arm, or in the passenger side jet itself.
On the washer jets on the wiper arms, the main outlets appear to have a slot-head screw - anyone know what this is for, is that for adjusting the flow/pressure on that jet?
Received 2,012 Likes
When I got my car (delivered from halfway across the country, sight unseen), I found the passenger side jet wasn't working, but I did get a small puddle under the car. Found that the hose was disconnected under the plastic cover that runs along the bottom of the windshield. It's glued down, so I had to gently pry it up (from the engine side IIRC) to get access to the hose connection (right about the center of the windshield). I reconnected the hose, and put a tiny hose clamp (from a drip irrigation kit) on it to keep it from blowing off again. Been working fine for 4 years now.
![Icon Denk](https://www.jaguarforums.com/forum/images/smilies/icon_denk.gif)
8bit (10-24-2018)
42Ajd
12-30-2015 09:45 AM
CaneCounsel007
11-13-2015 09:05 PM
al_roethlisberger
09-11-2015 10:04 PM
