Winter project: Quaife install/trans service.
Old 01-01-2016, 06:27 PM
flyc2c's Avatar
Default Winter project: Quaife install/trans service.
So I got a wild hair today. Been waiting for a long stretch of days off to get this project under way so with 10 days off I decided it's as good a time as any. ( I worked out of town the 23rd-26th of December so I deserve it.) Remembering the Jack's transmission removal I got the diff out today. Started at 2pm and had it out by 6pm taking my time. It was fairly cut and dry. Glad I had a transmission jack handy. Fluid looked awful after 50k miles. I'll be opening it up tomorrow. Ran out of daylight. More to come. Write up soon after.
This little jewel is heavy!
FrickenJag (01-04-2016)
Old 01-02-2016, 11:03 AM
amcdonal86's Avatar
Looking forward to reading the writeup! How much does all this cost?
Old 01-02-2016, 07:44 PM
flyc2c's Avatar
If you're talking about the differential I bought the Quaife from a member that never got around to installing it. They retail for a tad under $1500 US. $50 for bearings and $40 for seals and add some diff fluid. I also plan on adding a plug to drain the diff in the future. Add $15 for that. Can't really put a value on blood, sweat and tears. The trans service will run about $450 for the new pan and fluids. Car has just under 50K miles. It's due.
Old 01-03-2016, 07:05 PM
flyc2c's Avatar
So today I cleaned up the diff cover and removed all the old adhesive. Removed the half shaft seals and sacrificed only one pinky. Mashed it good! Bearings and races were picked up this morning. Tomorrow the old diff comes out and the Quaife goes in. There's a giant snap ring that I don't have the tool for and will acquire. Got to get new seals and I may get them from Ford. The number on the seal shows it's a Ford part number via Google. Otherwise I'll visit my local Jaaaag dealer. Taking many pictures.
Old 01-03-2016, 07:36 PM
Stuart S's Avatar
Received 6,319 Likes on 3,464 Posts
Subscribed.
Old 01-05-2016, 04:08 PM
flyc2c's Avatar
Jag **** NSFW! (not safe for wallet)
Gordo1968 (12-10-2017)
Old 01-05-2016, 04:11 PM
flyc2c's Avatar
Modified the diff cover and installed an NPT drain plug. Used a dremel to trim down the fin.
Inside required trimming a fin...
Old 01-05-2016, 04:54 PM
kj07xk's Avatar
Received 2,011 Likes on 1,344 Posts
Nice. Tapping the hole wasn't too hard, right? (remember to clean out those filings )
Old 01-05-2016, 05:15 PM
flyc2c's Avatar
Easy peasy. Trimming the fins was a pain. Used the matching drill bit and tap for the plug. I used a magnet on the (aluminum) shavings. LOL!
Old 01-05-2016, 07:30 PM
flyc2c's Avatar
Had to lower the trans an inch to get to the fill plug. PITA. Once I cracked it I could safely drain the fluid.
On the left is new ZF fluid. On the right is after 48k miles. Definitely NOT lifetime fluid! Have yours changed!
The following 4 users liked this post by flyc2c:
Joachim1167 (01-06-2016), Ngarara (01-06-2016), ralphwg (01-06-2016), Stuart S (01-07-2016)
Old 01-06-2016, 04:19 PM
flyc2c's Avatar
Today the Jag got re-assembled. Diff is in, suspension re-secured, driveshaft re-connected and transmission pan swapped. Tomorrow is fluids in both and re-install the exhaust if I'm not in too much pain from my 10am root canal. Maybe I'll work like crazy while I'm still numb! This project is going amazingly well so far although I'm growing weary from crawling around under the car.
Diff going in! New seals, new bearings and races and soon fresh fluid. Will use Motorcraft synthetic 75w-140 as per specification. $22 a quart.
Old 01-07-2016, 07:09 PM
flyc2c's Avatar
So at 10-11:30am I got a root canal on the back molar. Despite this I got the diff filled and the trans partially filled before I ran out of daylight. Tomorrow I'll be finished!
Old 01-07-2016, 11:01 PM
Stuart S's Avatar
Originally Posted by flyc2c
... On the left is new ZF fluid. On the right is after 48k miles. Definitely NOT lifetime fluid! Have yours changed!
... So at 10-11:30am I got a root canal on the back molar.
Looks like a glass of ale and a glass of stout to me. Your choice; just what the doctor ordered! I'm not sure what's worse - death, taxes or a root canal. Hope you feel better soon.
Old 01-07-2016, 11:25 PM
RedRider48's Avatar
This qualifies a s a sticky, correct?
Old 01-08-2016, 06:03 AM
flyc2c's Avatar
Thanks but no. There will be two write up threads. One for the diff and one for the trans. Coming soon.
Oh and Stuart, I prefer stout but I'll take either if you're buying!
Old 01-08-2016, 06:44 AM
tampamark's Avatar
You are the man! I will be very interested to hear the improvements in performance with the LSD. It should allow for significantly better hookup on acceleration.
Old 01-10-2016, 11:37 AM
flyc2c's Avatar
Old 01-10-2016, 12:02 PM
kj07xk's Avatar
Well done!
Again you've provided an excellent how-to guide.
Now for the 'stupid question' - have you taken it down from the jacks and tried it out?
Does it meet your expectation?
And how does it sound? (I've read reports of extra noise coming from them).
Again, thanks for the terrific write-up!
Old 01-10-2016, 12:37 PM
flyc2c's Avatar
Well done!
I'll do it this way..
Yes.
Beyond.
Quiet as OEM.
My pleasure!
Old 01-11-2016, 02:31 PM
DGL's Avatar
DGL
DGL is offline
Well done. It's a long way before the winter is over. What's next?
