Winter Project: Salvaged 2008 XKR
Old 07-06-2013, 11:13 AM
Stuart S's Avatar
Received 6,290 Likes on 3,452 Posts
Originally Posted by Ngarara
Hmmm - mine doesn't work that way, but it's an MY11 car so the ECM and/or firmware will be different. If I forget to stand on the brake and just push Start, the car switches to active mode and everything lights up. I then have to press the pedal and push Start again - just hitting the pedal does not initiate cranking.
Since the OP's car is MY08, it will probably behave like yours. But there will still need to be sufficient pressure in the braking system to reach the threshold to allow cranking.
Interesting, Ngarara. I note that you're in the UK. I wonder if the same year US and UK models are identical in this regard? Specifically, will a UK 4.2L start if you press the START button before depressing the brake pedal? What about a later model US 5.0L - will it start that way, or do you have to depress the brake pedal first? If you have to depress the brake pedal first, I wonder why the engineers made the change?
  #42
Old 07-06-2013, 11:21 AM
jgraff's Avatar
It looks like I owe Ngararaa beer, cause I bled the braked again, and wouldn't you know the car started right up!!!
Lots of white smoke for the first minute (had squirted some penetrating oil in the cylinders to get them running) then settled down.
runs really nice, idling at about 600 RPM...
No warning lights.
I am a bit nervous about oil pressure. there is no guage, and no way to tell it i have good pressure (except the idiot light, which is ok)
the oil filter and pan are hot. but strangely the oil coolers are not hot at all. read in the shop manual that they may only get flow once the thermostat opens all the way. and I haven't run it long enough cause i am worried about pressure...
anybody know if the oil coolers get fluid all the time, or whether they only get fluid once a certain temperature is reached?
thx for all the help and moral support!
-jg
  #43
Old 07-06-2013, 11:54 AM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Heh - inspired guess, but it was mostly the way it just turned off when you hit Start in the video.
The idiot-light system is self-checking - if the monitoring sensors don't work, you get a warning. So you're probably fine, but I understand the nervousness! There is bound to be somewhere on the car where you could connect a conventional pressure gauge in the oil lines, but I lack the knowledge. Does the workshop manual give you any hints?
  #44
Old 07-06-2013, 12:30 PM
Stuart S's Avatar
No warning lights.
-jg
jg-
I'm sure you had the same feeling of relief as I had when my wife delivered our first child! Way to go! Reading this thread has been a real cliffhanger! Can't wait to see the video of you driving it for the first time!
Stuart
  #45
Old 07-06-2013, 06:51 PM
jgraff's Avatar
recalled to life...
2008 Jaguar XKR back on the road.... click link below to see the video....
View My Video
The following 7 users liked this post by jgraff:
CleverName (07-07-2013), D-end (07-07-2013), Gary87Zx (11-25-2013), jagxk2008 (07-07-2013), Muddydog (07-07-2013), Stormdk (12-04-2013), Stuart S (07-06-2013) and 2 others liked this post. (Show less...)
  #46
Old 07-06-2013, 07:45 PM
Donzi's Avatar
You deserve to be knighted by her majesty the queen!
Excellent job SIR!
  #47
Old 07-06-2013, 08:05 PM
richzak's Avatar
Received 1,233 Likes on 789 Posts
Awesome accomplishment.....you should be very proud.
You now have a $40,000+ Jaguar XK Coupe.
You deserve a Phoenix Award
  #48
Old 07-06-2013, 11:02 PM
Ngarara's Avatar
A resurrection worthy of Lazarus! This just proves that some "write offs" can be restored to full health, provided you're patient and diligent, even if they're complex modern cars.
Well done mate - I look forward to seeing more pics & vids as the work is completed.
  #49
Old 07-07-2013, 02:32 AM
Received 1,231 Likes on 716 Posts
Nice one JG, that's a pretty impressive turn around.
  #50
Old 07-07-2013, 03:01 AM
jagxk2008's Avatar
recalled to life...
View My Video
So it runs fine? it seems the dog approved it...cool video...
  #51
Old 07-07-2013, 12:55 PM
CleverName's Avatar
Congrats good sir!
Thank you for tackling this project and keeping us posted! What an amazing feat!
Vince
  #52
Old 07-07-2013, 01:59 PM
flay's Avatar
Great job! I have such project on my to do list as well (I found only 15-18 k damaged XKR's on American sites).
Reading how the engine was not starting, I remember the emotions on the first attempt to start my XJ8 after converting it to LHD , failing because one main connector was not seated properly.
  #53
Old 07-07-2013, 08:26 PM
ralphwg's Avatar
Received 1,209 Likes on 915 Posts
Amazing!! Simply amazaing!!! Good job and congratulations. Can't wait to see more!!
  #54
Old 07-08-2013, 05:16 AM
rscultho's Avatar
Congratulations man - great job! Great that all the systems retained their programming...
So, if it's not too rude to ask, how much do you have into your project? Will you have saved a good bit over having just bought one?
I think part of doing this was the adventure of rebuilding such a car.
Will you have a salvage title or will you be able to get a regular title?
  #55
Old 07-08-2013, 12:49 PM
DGL's Avatar
DGL
DGL is offline
Good luck. Wish I could help you.
  #56
Old 09-29-2013, 12:43 PM
flay's Avatar
How is the job with the car? Is it true that the chassis panels are not welded but glued and riveted?
  #57
Old 09-30-2013, 11:20 PM
Gary87Zx's Avatar
Just found your thread. How's the rebuild going? An impressive project that I wouldn't dare attempt. As they say in England: Best Of British Luck!
  #58
Old 10-08-2013, 03:44 PM
R_Rated's Avatar
Just curious but what was the total investment and what did the shell cost?
  #59
Old 10-09-2013, 03:32 PM
Marko's Avatar
Amazing stuff, keep us updated!
  #60
Old 11-22-2013, 08:54 AM
mark campbell's Avatar
congrats-------moving along nicely --nice to see i,m not the only slightly damaged jag lover i have a few ---will keep up with your progress
Quick Reply: Winter Project: Salvaged 2008 XKR
