Wood trim
Is there a difference with the wood trim from the 2007 to present cars. Also does the wood trim for the XKR have the R logo on the glove box piece or is it all wood. I have the Aluminum finish in my 2012 but am considering replacement of the 4 pieces (glove box , under gauge and the 2 at the window switches) if I find a used set sometime in the future.
Mine is a MY11. The wood glovebox piece has an R on it. I'd have loved to swap mine for yours, but mine is set up for RHD and the pieces would be different. I also had the centre console and shifter surround in wood. It is all wrapped now, I couldnt stand it (just different strokes, I suppose).
Sorry Tom I thought I responded but I see it didn't go through. What i am looking for is an extra set of wood trim. Specifically a 4 piece set in burl or walnut. I have the black onyx surround (will keep this even with wood) and center console with the aluminum glove box and over steering wheel trim along with the 2 pieces near the window switches. I would like to keep these pieces and get a 2nd set in wood. Thank you for the offer though.
OK i'll keep it in mind. This also brings another question and do I assume that the XJ trim is the same as the XK. Also is the 2006 -2015 XK trim all of the same too.
I have attached the fitting instructions.
The XK wood has essentially remained the same from the 2006 (2007 in North America) to the present - with the shape of the console piece around the shifter being the only change in shape or fitting. Various woods and finishes (gloss, satin...) have been used, just as in the sedans.
The wood is a veneer (as in all luxury cars) attached to a metal substrate.
