World's quickest/fastest 4.2L XKR... again.
There is very little free space under the bonnet in the XKR, there is a spot where a 2-3 litre tank could fit, but it would have to be custom fabricated to fit, which would be quite expensive to produce unless you're a fabrication guru who can cut, shape & weld aluminium yourself. Which i'm not....
hint my tank is not in the engine bay, its behind the front bumper beam in the front of the front wheel arch . on the under side of the inner gaurd.
i cut mine out with card board . and had a mate fabricate it . .
my guess is that space for your car is about to be filled with air filter pods .as jahummer advised .
if your lay out is similar to the x100 front guard , there is nice rectangular space behind the guard/fender and the chassis.
behind the wheel arch ,
where the x100 kept its overflow tank . i expect its different but , might be worth a poke around .
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1297x975/dsc03498_7d0177a81ab4979439988f423fbda7cc6dac021f.jpg)
There is a little room above and behind the front bumper but not much.
Jaguar Forums Editor
Jaguar Press release
03-01-2016 11:48 AM
