Would you replace this tire?
I discovered a screw in my tire so I had discount tire order a new one. Once the tire arrived I took my car there and they yanked out the screw and said they wouldn't replace the tire unless it was leaking air. Thoughts? Does it look like it will be ok or should I take it to another location.
Tires shops are required to turn away any repairs that involve the outer shoulder section. They use a schematic which depicts areas of the tire to avoid. Generally, the center tread areas are acceptable depending how far away from the outer shoulder. Also the size of the puncture is a determining factor. Your puncture does look to be part of the tire shoulder. I wouldn't repair it even if you find a shop that will plug it. Not worth your life.
Tires shops are required to turn away any repairs that involve the outer shoulder section. They use a schematic which depicts areas of the tire to avoid. Generally, the center tread areas are acceptable depending how far away from the outer edge. Also the size of the puncture is a determining factor. Your puncture does look to be part of the tire shoulder. I wouldn't repair it even if you find a shop that will plug it. Not worth your life.
They didn't turn away the repair. They refused to replace the tire that I had just ordered under warranty because it wasn't leaking or "deep enough".
To your question, my money, my safety. Yes I would replace the tire then any warranty fight could come after they hand me the tire and it can be inspected from the inside. If I lose, I lose some money only. Now the fight becomes interesting given the tread wear on the tire in relation to the others. If I now have to buy two because the tread life, it raises the stakes but to me, I'm still replacing.
The following 3 users liked this post by Sean W:
ralphwg (05-28-2022)
Received 2,048 Likes
I'm always interested in differences in vehicle safety regulations across the World and also how member perception varies so I'll pitch in with my experience on this issue.
I've had three similar instances over the years where a screw or nail has penetrated the tread but NOT the sidewall. Two of these happened in England and one in Spain. A tread repair could have a slow leak if not done properly but it's not going to cause a blow out. Sidewall damage is a totally different situation and is definite immediate replacement for me.
For tread punctures, in the UK it's common practice to dismount the tyre, deliberately make a clean hole and fit a mushroom plug from the inside. The plug has an adhesive base and sticks to the inside - the excess 'stalk' is trimmed level with the tread. In service, air pressure and centrifugal force presses the plug base onto the surface and I know from inspection at eventual tyre replacment time, those patches are never going to move.
I've felt perfectly safe with this kind of repair and never had any subsequent issues in either instance. One was on my Jaguar X308 and the other on my Bentley Continental GT. I didn't consider replacement was necessary in either case.
The third instance happened in Spain on my last XK which fortunately had a space saver spare. I took the wheel to one of the major tyre depots for repair and was horrified to be told:
1. they were NOT ALLOWED to do a repair
2. replacement tyres MUST be fitted as axle sets - 2 new tyres required
A second depot told me exactly the same so it wasn't a case of fleecing the tourist and demonstrated how very different regulations are in different countries. A 25 UKP repair at my local tyre depot against more than 1000 UKP for replacements in Spain.
I ordered an emergency repair kit from the UK and had it delivered to me in Spain. The repair was completely air tight until I got home and had it repaired professionally at my local depot.
The following 2 users liked this post by Stuart S:
mosesbotbol (05-26-2022),
I would replace the pair. Just not worth doing it half-assed with one tire.
jons (05-26-2022)
My local dealer stopped doing tire warranties. Getting money from the insurer was too difficult and wasn't worth the little or no profit they offered the warranty to their customers. They charge the same as Tire Rack.
If they Patched it and not plugged it you should be good! Discount Tire always have some bullsht rules that's why I stop going there. Before you purchase them they tell you about they lovely Warranty and Tire replacement. If you don't feel comfortable with tire send corporate a email and picture and telling them how you don't feel safe that will put pressure on store manager.
