Wow. On a road trip and my cat misbehaves... BAD Kitty
#42
So I'm 5 hours from home, and suddenly everything in my car "Clicks".
The dash clicks, the seatbelts click, something in the fuse panels behind the rear seat clicks...
Every alarm light on the cluster lights up and both dials drop to zero.
Then message alerts start rapid firing on the center display.
Engine overheat
Battery not charging
Cruse control unavailable
Cats system fault
Oddly, the car is still purring down the road...
Within 5 seconds the dials spring to life.
So I pull over, run a scan on the OBD port and only get two errors.
U0405 and U0155
I write them down and clear them. All the warnings go away except the Cats system Fault.
Curiouser and curiouser....
Watching critical thing like engine temp (Stable as a rock) I drive on.
An hour later... It does the same thing.... Pulled over... Same codes... reset, and now in a hotel researching an answer
Ideas?
I'll search more, but how do I do a full ecu reset? I'd like to see if that clears he cats error, as my ODB reader does no see it in the error tables.
Bad kitty..... (but I still lover her, and gave her a bath before pulling in to the hotel)
Engine overheat
Cats system fault
U0405 and U0155
Ideas?
I own a OBD-II bluetooth connector. Taking out immediately.
Queen and Country (01-29-2019)
Aus V8S
11-13-2015 11:01 AM
neruda
10-18-2015 01:19 PM
02jagstype
09-04-2015 08:20 PM
