Wow what big exhaust tip I have
Old 05-02-2014, 03:45 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Default Wow what big exhaust tip I have
OK so today I'm going through the inspection and the insurance photo's and then started to do some more clean up. I got a note to the dealer on how I was not happy about the detailing on the car. Looks like they just washed it and wiped down the interior. So while cleaning I see the quad exhaust tips are 3 1/4" dia. Pretty big and I don't remember them being that big on the 2010 I drove. Next as I was trying to sync the garage door opener I got the BATTERY sign on the main screen. So I opened up the rear left vent panel in the trunk and put my 10 amp charger on it. Seems like it was drawn down at the dealers . I also noticed that the dealer had the battery cover off as the 4 screws were in a plastic bag. Next week I'll pull the battery cover and see what's going on and while I'm there will most likely put on a wire for the smart charger. I also had fun today but had a major problem. I am having a hard time keeping it under 70 , LOL
Old 05-02-2014, 04:14 PM
Jffcurt's Avatar
I wouldn't let the dealer wash my car if they run it through a machine. Only hand wash or touchless. You don't want swirls on the paint of your new car!
MaximA (05-03-2014)
Old 05-02-2014, 06:23 PM
richzak's Avatar
Received 1,233 Likes on 789 Posts
You can detail the car yourself...
1) Hand wash it.
2) Clay Bar the entire car (1 hour) Buy the Mothers or Meguiars Gold Clay bar kit $20.00
3) Buy a can of Meguiars NXT Generation 2.0 Paste Wax and apply ($22.00) Buff the wax with microfiber towels.
4) Buy a few quality MicroFiber towels ($7.00 to $8.00 each)
5) Apply 303 High Tech Fabric Guard to the covertible top with a high quality paint brush. (303 High Tech Fabric Guard 32 oz bottle).
All of these products are available at Amazon.com
Your car will look great.... guarenteed.
MaximA (05-03-2014)
Old 05-02-2014, 06:50 PM
richzak's Avatar
If you decide to go with a smartcharger like a CTEK brand, the charger will come with a harness that has eyelets that will connect to the screw post of the positive side of the battery. Since your Jag is a 2012, I understand that you will need to put the black (neutral/negative) wire to a ground post on the chassis rather than the negative side battery terminal. I understand there is a ground post in the spare tire wheel well.
Old 05-02-2014, 07:00 PM
jagtoes's Avatar
Thanks Rich. Today I used my 10Amp charger to bring the battery up to normal charge. I used the + stud in the left hand grill in the boot and the stud in the spare tire well. Had it on for 3 + hours and it is almost fully charged. I then put the smart float charger (2.2A) on and left it there for the night. Hopefully the dealer didn't toast the battery while it was sitting unused for almost a month. We'll just have to wait and see. As far as the detailing is concerned I don't have a problem doing it and my bet is it won't need claying. I'll look at that next week.
Old 05-02-2014, 07:24 PM
richzak's Avatar
Using the clay bar kit is extremely easy, and you would be surprised at the amount of contaminents that you will get off the surface of the paint.
The paint surface is most likely NOT as smooth as you might want it to be. For a small price of $20.00 bucks for the clay bar kit, when the Jag is worth thousands, it is worth at least giving it a try.
My 2014 Porsche 981 only had 1400 miles on it when I clay barred the car. It sat outside on the dealers lot for several months. The surface of the paint is now smoother than a baby's butt. And that is pretty smooth. Adding a coat of good wax after clay barring will add to the beauty of the car, especially with the Italian Racing Red paint.
Old 05-02-2014, 07:32 PM
amcdonal86's Avatar
Rich, is there a reason this is different for 2012 models?
Old 05-02-2014, 07:35 PM
amcdonal86's Avatar
Regarding clay bar: make sure you are using a pretty mild clay if you are not going to do a machine polish afterwards. Some types (Meguiar's C-2000 Professional detailing clay, for example) are very harsh and marr the paint. These, however, are very good for removing paint overspray.
Probably any clay you find in the auto parts store is perfectly fine. Just keep it lubed up with lots of liquid (water or quick detailing spray).
Just FYI!
Old 05-02-2014, 08:35 PM
richzak's Avatar
Just FYI!
Both the Mothers and Meguiars Clay Bar kits ($20.00-$22.00) come with 2 bars that are "fine" clay, you get a bottle of "detailer lubricant" spray, and a microfiber cloth.
You are correct, water and the detail spray is needed. The results are awesome. Many people don't want to clay the paint surface, because they think it is abrasive and can ruin the paint. Also many people don't understand the clay bar process and how easy it is to use.
There are many contaminents that get on the paint. The only way to eliminate them is to clay bar the paint surface. For $20.00 and an hour of work, it is now my #1 recommendation, when a car owner opens up the topic of detailing.
Old 05-02-2014, 08:52 PM
bocatrip's Avatar
I remember reading this as well somewhere about having the negative charger lead going to a ground rather than the battery negative pole.
Old 05-02-2014, 10:55 PM
Del Boy's Avatar
Wonder why? In my 2012 it's connected to the negative post on the battery.
Old 05-02-2014, 11:05 PM
DGL's Avatar
DGL
DGL is offline
I have my pig tail wires connected to both terminals of the battery. My negative wire is connected to the negative battery terminal and not the negative post under the spare tire. Is this a problem? I haven't had any problems, so far.
Old 05-02-2014, 11:27 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
Attaching the negative battery charger cable to the remote terminal under the spare tire is safer than attaching it directly to the negative battery terminal. How much safer is debatable.
All batteries emit hydrogen gas, which is highly explosive. Since the battery is in a small compartment there is a risk that hydrogen gas can build up even though the battery is vented to the outside. Hydrogen gas is colorless and odorless and you can't tell if it's there until it's too late. Connecting or disconnecting the (-)battery charger cable at the (-)battery terminal post can cause a spark and KABOOM! No such risk if you connect the (-)charger cable to the remote (-)terminal under the spare tire.
I connected my BatteryMINDer smart charger (+)cable to the remote (+)terminal behind the cover on the left side of the trunk and the (-)cable to the remote (-)terminal under the spare tire. I used the alligator clips that came with my charger and haven't had any problems for more than 2 years. Copied below are the detailed photos from my post #21 in this thread:
https://www.jaguarforums.com/forum/x...s-73471/page2/
Cover for battery remote access +terminal in left fender:
Note the black quick connect wire running from under the luggage panel floor to the remote access panel.
Quick connect + lead alligator clip attached to the remote access +terminal:
The quick connect - lead alligator clip is attached to the -remote terminal in the spare wheel well:
Quick connect leads connected together in the trunk:
Trunk lid closes over the wire with no problems:
Stuart
Attached Thumbnails Wow what big exhaust tip I have-7184739599_e727686c1c_z.jpg   Wow what big exhaust tip I have-7184735611_938b0d9d0f_z.jpg   Wow what big exhaust tip I have-7369973098_f8914cf3ee_z.jpg   Wow what big exhaust tip I have-7369971636_efb6f0a6ae_z.jpg   Wow what big exhaust tip I have-7185512925_a61e0c12fd_z.jpg
Old 05-03-2014, 03:48 AM
u102768's Avatar
Received 1,490 Likes on 908 Posts
It is because of the battery monitoring system:
When using a Jaguar-approved battery charger or maintainer, connect the charger to the recommended ground point to ensure that the charge flows through the BMS module instead of the negative battery terminal.
Failure to observe this will log a diagnostic trouble code (DTC), and incorrect battery condition information will be retained by the BMS module due to unmonitored current flow into the battery. However, the system will recognize and compensate for the change in the battery status after a period of time.
Del Boy (05-03-2014)
Old 05-03-2014, 06:35 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Clay bars are a dying breed. Products like NanoSkin AutoScrub Fine Wash Mitt are faster to decontaminate the surafce and can be used again if they fall on the ground. If using clay, consider using CarPro IronX before claying the car. Speeds the claying process significantly, plus is a really product.
Old 05-03-2014, 06:53 AM
jagtoes's Avatar
[QUOTE=Stuart S;967141]Attaching the negative battery charger cable to the remote terminal under the spare tire is safer than attaching it directly to the negative battery terminal. How much safer is debatable.
I attached my 10Amp charger to these points and there didn't seem to be a problem charging the battery. After it was charged I put my 2A smart charger on and it went to "float" state so no problem. That being said do I ASSUME that this remote + terminal is a straight wire going back to the + battery post. If so then there would be not reason to attach the charger to the battery other then convenience. I did notice that the 2 dealers I stopped at had the chargers hooked up in the trunk left grill. Even had them on the new F-type in the showroom. So I'll go with this approach until I have to remove the battery and then I'll hook up a lead direct to the + post on the battery. We'll see.
Old 05-03-2014, 09:27 AM
amcdonal86's Avatar
Do AGM batteries emit hydrogen gas as well? I thought some of them are ventless!
Old 05-03-2014, 11:07 AM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
It's all about the battery monitor on the 5.0 cars. it can get upset if the charging bypasses it by connecting direct to the -ve terminal. If you connect to ground elsewhere, the monitor 'sees' the charge going in. I asked Jaguar, and this was the response:
Battery conditioners supplied from Jaguar Features integrated wiring and a dedicated DIN socket within the loadspace area, providing convenience and ease of use. part number C2P24103. But yes if you are using a normal charging leads red leads goes on the positive post and black lead connects to a chassis ground point
Old 05-03-2014, 11:30 AM
bocatrip's Avatar
I have a 5.0 car with the battery monitor and have the charger connected to both battery terminals with no issues so far. Should I be changing the negative connection to a ground in the trunk area or can I get by? Will I be looking at any problems down the road with my present hook up?
Old 05-03-2014, 01:22 PM
richzak's Avatar
Jaguar Part #C2P24103 is a CTEK product, with the Jaguar logo on the face of the charger. This part number retails for over $180.00 MSRP and cannot compare with the CTEK for $52.00 from Amazon. The CTEK 3300 is a superior charger over Jaguar Part C2P24103, has additional functions and uses a 120v wall socket to provide power to the battery.
In addition Jaguar Part #C2P24103 has a cigarette plug in for the power. I would not use this is my car.
Ngarara provided the reason for not hooking the CTEK eyelet to the negative battery post due to the battery monitoring module. I have the 4.2L engine so my CTEK 3300 eyelet connectors are fastened directly to the battery terminal screw posts. Since I am NOT an electrical engineer, I am not sure of what the consequences might be by attaching the CTEK eyelets to the neg side of the battery in a 5.0L engine Jag with a battery monitor module. Perhaps someone else might know the potential ramifications. Certainly Ngarara and White XKR are the electronic experts here on the forum, so perhaps either member can shed some more light on this issue/topic/discussion.
Quick Reply: Wow what big exhaust tip I have
