Wrecked, Crashed, Salvage: Pity the XKR-S
Old 05-29-2019, 10:04 AM
R Bhal's Avatar
Default HELP -2012 XKRS Engine replacement
Hello all-
I am/was the proud and happy owner of a white 2012 XKR-S which I have driven on many many car rally's and taken to the track.
I was a proud brand ambassador - until this past weekend where while driving spiritedly I heard a clatter and then the car shut off.
I am told by Budds Jagaur in Oakville Canada that it may be a bent valve (engine not turning) or complete engine replacement as a worst case scenario.
Where would I start to source a used XKRS engine?
Old 05-29-2019, 10:11 AM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Originally Posted by R Bhal
Hello all-
An R-S engine would be difficult to find but I believe you can install the XKR engine and give it the R tune. You could also use all of the functioning parts of your old engine if necessary. Good luck.
Old 05-29-2019, 12:04 PM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
Originally Posted by jagtoes
An R-S engine would be difficult to find but I believe you can install the XKR engine and give it the R S tune. You could also use all of the functioning parts of your old engine if necessary. Good luck.
Oops. I fixed it for ya.
Dang Typos anyway.
jagtoes (05-30-2019)
Old 05-29-2019, 08:00 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
Wait... what? How do I get the S tune?
vintageyz (09-11-2019)
Old 05-29-2019, 08:15 PM
Cee Jay's Avatar
Have the correct VIN???
I'd like that myself, but it eludes me so far.
Old 05-29-2019, 08:55 PM
Received 4,458 Likes on 2,427 Posts
The XKR-S engine is identical to a 2012MY-onward XKR, you could swap one for the other. There were some changes at VIN B47117, like the supercharger bypass changing from a vacuum actuator to a stepper motor, and some small details, and you need to check that the VVT units are are the same on the donor motor as the original.
The engine tune is in the PCM, which you wouldn't be swapping from a donor car anyhow.
You could also take a 5.0L S/C motor from a 2010-2013MY XJ SuperSport, an XFR up to 2012MY, and if you're really stuck a 2010-2013 Range Rover Sport L320, or 2010-2012 Range Rover L322, but if you take the Range Rover motor you'll need to swap the sump, and a lot of bolt-on accessories as well.
Sorry to hear about your motor, but as you can see, there are ways around it.
Old 05-29-2019, 09:05 PM
XKR-S VIN won't help you.
If you want to put the XKR-S tune in an XKR, it's not going to bring you much more power unless you change the exhaust to the XKR-S one, or of a similar design.
The only difference in the XKR-S tune vs the XKR is torque limiters are raised, but the XKR-S can breathe better, because of the exhaust. So the tune complements the exhaust, so to speak.
Or you know there is a proper 600+ hp tune which can be flashed to a 5.0L XKR using SDD, yeah?
The following 3 users liked this post by Cambo:
Cee Jay (05-29-2019), kj07xk (05-29-2019), sparky fuze (05-29-2019)
  #28
Old 05-29-2019, 09:16 PM
Cee Jay's Avatar
So where and how would a person procure this particular specimen?
The following 2 users liked this post by Cee Jay:
Old 05-30-2019, 02:53 AM
u102768's Avatar
Received 1,490 Likes on 908 Posts
I can recommend it
  #30
Old 05-30-2019, 06:47 AM
jagtoes's Avatar
I didn't think about this but are you saying if you replace the ECU of a 5.0L XKR with one from an XKR-S then you would get the 550HP . This assumes you would have the PAE option. Is that correct ?
  #31
Old 05-30-2019, 08:03 AM
sparky fuze's Avatar
From forum member u102768 signature
"Current Jag: 2010 5.0 XKR (XKR-S X-Pipe, smaller pulley and tune ~630bhp - 11.925@120.59, max v=124.63!)"
  #32
Old 05-30-2019, 10:37 AM
Cee Jay's Avatar
I've heard that putting in a different ECU would clash with the current VIN. Could probably be done, but with more finesse.
  #33
Old 06-02-2019, 07:10 PM
  #34
Old 06-03-2019, 12:18 PM
Hello all-
Not sure, but the engine may still be available from this "R" located in Toronto...
https://www.kijiji.ca/v-other-auto-p...ationFlag=true
  #35
Old 06-03-2019, 12:33 PM
This one is a XFR but has basically the same engine...probably be ~$2,000 to ship it from Red Deer.
https://www.kijiji.ca/v-cars-trucks/...ationFlag=true
  #36
Old 08-05-2019, 11:57 AM
TraxtarXKR's Avatar
Is there a way to determine what salvage yards these cars end up at so we can inquire about parts? Just searching the VIN usually ends up with results from poctra or similar auction sites, which just say that the vehicle was 'sold'. I doubt they would provide info for the buyer of the car.
  #37
Old 08-05-2019, 11:10 PM
ralphwg's Avatar
Received 1,211 Likes on 917 Posts
Try Pacific Motors in the Detroit MI area and Jaguar Heaven in CA.
  #38
Old 08-06-2019, 08:08 AM
guy's Avatar
guy
guy is online now
Received 1,125 Likes on 792 Posts
Originally Posted by kj07xk
Ya know, a lot of these cars appear to have similar damage, which could probably be attributed to a failed front parking sensor.
XKR-S owners... Get your front parking sensors checked out!
hmmm, if you can't drive without the aid of sensors... should you be driving?? Sorry, couldn't contain myself.
  #39
Old 08-06-2019, 04:55 PM
TraxtarXKR's Avatar
I've reached out to the following:
Pacific Motors (Very difficult to work with)
Jaguar Heaven
JagBits
Galaxy Jaguar
Welch Enterprises
Coventry West
XK's Unlimited
Brooks Jaguar Parts
None of them have purchased an X150 for their yard in a very long time... let alone an XKR, XKR-S or similar performance version.
These cars must go somewhere, but I don't see them listed for parts online or eBay. Very strange! Considering the rarity, you'd think they would be easy to trace.
  #40
Old 09-05-2019, 02:49 PM
TraxtarXKR's Avatar
I contacted this guy... but he's got VERY high prices on his parts. Wanted $800 for the spoiler alone, and non negotiable. He also has an exhaust for the car.
Quick Reply: Wrecked, Crashed, Salvage: Pity the XKR-S
