x pipe exhaust question
I have an Arden rear section exhausted fitted on my XKR but to my surprise it isn't any louder than the stock exhaust. The tone is lovely but it certainly isn't loud enough for me.
I've read a few posts regarding the x pipe/center muffler delete options I wanted to know if you would expect a noticeable sound increase fitting one? There seems to be differing opinions on how much difference they make. Also are there any that sound any different from one another? I can see that Arden, Magnaflow and Adamesh all supply them.
Thanks.
Thanks.
Received 1,975 Likes
To the OP:
On the XKR, which has two mid section silencers, removing one to add the X-pipe should increase the sound, and removing both should crank it up even more.
Another tactic some on this forum have used, is to replace the catalytic converters with units that have a lower 'cell' count, which decreases restrictions on the exhaust flow, and can significantly increase the sound. Search this forum for 200 cell cats, or even 100 cell cats, and you'll find more info.
My exhaust guy did it for a few hundred dollars, from memory. X pipes are a fairly standard modding part, if you take your car into a decent exhaust shop they will put it up on the hoist and get the measurements, I think it will cost you far less than Adamesh have quoted.
This is what it looks like.
Facebook Post
mosesbotbol (09-07-2016)
As I've read the various posts over time exhaust sounds seem to be bought up a lot. It is hard to tell who likes what and what is the best sound because everyone has their own tastes. In my youth it was my Daimler SP250 that sounded the best then the side pipes on the Vette and then the uniqueness of the Ferrari V8. I just attended the vintage car races at Lime Rock park and the ranges of open exhaust has gone from 4 bangers up to the thundering Trans AM V8's. Where am I now is with what I got. I think sound wise the best of both worlds is with the 5.0L S/C with the active exhaust. With the top down and cruising in a normal drive mode there is a low exhaust note but when you hit the go peddle the noise generated is great. Also with the top up and cruising at 70 there is a silent rumble which doesn't impinge on the stereo. I know I wouldn't enjoy driving 3-4 hours with the pipes open (fuse 19) but it's nice to know you can open them up with a switch. Just my opinion.
This is the XFR-S driven hard, it had the cross pipe and sounds similar to the XKR with the cross pipe and resonator delete, though there are some other slight differences.
The XKR coupe doesnt get the sound into the cabin as much because of the fixed rear windows. I took the rear windows out when they were being tinted and the difference was significant (for the better).
Good idea flyc2c, there's a cheap xk mid exhaust section for sale local to me so I will buy that and replace the one silencer with an x pipe. Rung a couple of exhausts shops who said they would have to make the x pipe and therefore I would need to leave the car with them. So, I'm going to order an x pipe online that way its just a simple and quick job for the shop.
Does anyone know what diameter x pipe I should order? Seen the X100 XKR is 2" with a 2.25" x pipe slipping straight over. Is the X150 the same?
For me it isn't the noise outside but inside. I have my limits to what I'll tolerate inside the car. I've achieved my personal balance with the XK mide pipe and fuse 19 pulled. Everybody likes their own flavor!
The XK centre section has arrived! Going to take it into the exhaust shop next week to get it swapped over and x pipe installed. I'm pushed for time so don't want to leave the car with them whilst they make an x pipe. Does anyone know what size is required so that I can purchase online beforehand?
Also what does the XKR sound like with straight pipes to the back box, is it too loud or any drone noise?
