x pipe exhaust question
Old 09-13-2016, 10:43 AM
mikexkr's Avatar
I won't have the option to reinstate fuse 19 as I have an aftermarket back box (Arden).
Has anyone tried straight pipes rather than the x pipe? Does that cause any drone? Just wondering what the reasons were for the x pipe really.
Old 09-13-2016, 11:22 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
The X-pipe equalizes the pressure surges between cylinders (mostly 6 and 8), giving a more even flow and sound. Maybe a couple ponies at higher RPM.
Old 09-14-2016, 12:43 PM
SickRob's Avatar
So how do the neighbors like the new exhaust system?
Old 09-14-2016, 02:08 PM
Cee Jay's Avatar
I'm "nice" about it around home, I don't let loose until get a few hundred yards away. (most of the time) Either way, no one has really said anything.
Old 09-14-2016, 03:19 PM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
I am waiting Spires to sell an X pipe for the 3.5 V6 in my XE. I figure I should start with that before doing a whole exhaust or should I go exhaust first then X pipe?
Old 09-14-2016, 03:22 PM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
Re fitted my x-pipe mid pipe last night.
The wife has the car today i wonder if she will notice the difference and the other thing is will it make a gain down the strip next week.
Old 09-14-2016, 03:33 PM
steve_k_xk's Avatar
Moses just confirming you have the supercharged 3.0 in you XE not a 3.5
  #28
Old 09-14-2016, 04:58 PM
BruceTheQuail's Avatar
Received 1,300 Likes on 895 Posts
I would have guessed that x-pipes from the f type would fit the XE. There is a thread in the f type forum about using them in the V6, though I think that one poster made the point that the exhaust system uses one anyway.
Personally I'd try the x pipe before doing the whole exhaust. It is an ultra cheap mod, and pretty effective.
Old 09-15-2016, 07:22 AM
yes, the 3.0 supercharged... I am always confused on the size of this engine. I thought the back said 3.5? I debadged it:
  #30
Old 09-15-2016, 03:13 PM
steve_k_xk's Avatar
In Australia the 3.0 s/c comes out with a S badge on the right hand rear .
The 2.0 turbo is badged as a 2.5t .. strange .
I miss the days when badges actually meant something not just a random series of numbers !
Attached Thumbnails x pipe exhaust question-de26342d60ac7f784334564b451f3932.jpg   x pipe exhaust question-cd4724418225992661739.jpg
  #31
Old 09-16-2016, 04:23 AM
steve_k_xk's Avatar
What a difference the x-pipe makes to the low down torque of the n/a 4.2.
I have always stated that the 4.2 absolutely loves to sing at high revs but below 3500rpm it has a large hole in the rpm range, the x-pipe has definitely solved this problem it feels a lot stronger throughout the entire rev band now.
  #32
Old 09-19-2016, 07:23 AM
mikexkr's Avatar
I now have the XK center section fitted with the one silencer. It is probably 20% louder and the sound is much more raw - I like it! What it has highlighted though is a bit of a drone between 2-3000rpm, it sounds very similar to a misfire but don't think it is. I could just notice it prior to changing the exhaust, has anyone else encountered this? Is it just the firing order that the v8 has? Thinking of continuing to the x pipe in case it evens out the flow.
  #33
Old 09-19-2016, 02:28 PM
SickRob's Avatar
Thanks for the input, as I am interested in doing some exhaust work on mine. I don't drive between 2-3k rpm enough to worry about drone, lol.
  #34
Old 09-29-2016, 07:19 PM
tberg's Avatar
Received 2,579 Likes on 1,419 Posts
I had my X-pipe installed yesterday. I removed the middle resonator but kept the rear one. I wanted to hear it with one first before I made a decision as to whether or not to remove the rear one. I can't believe the difference. It is hardly noticeable in gentle acceleration up to about 3000rpms, but if you step on it, it's incredibly more aggressive with a deep, luscious groan. Now maybe it's because I hear it more aggressively, but my butt test tells me that performance seems improved as well. Now I have to decide if I want to take out the rear resonator for an even more aggressive sound. No sign of drone, in fact, no difference whatsoever at cruising rpms 2000-2500. I will try and get some sound bites soon. For a couple of hundred dollars and an hour of my time, it was well worth it.
The following 4 users liked this post by tberg:
mosesbotbol (12-08-2016), ralphwg (10-01-2016), sherbercars (09-30-2016), SickRob (09-30-2016)
  #35
Old 12-07-2016, 04:45 PM
trkyam's Avatar
What size diameter X-pipe for a 5.0L XK ?
Thanks!
  #36
Old 12-07-2016, 05:32 PM
tberg's Avatar
I believe they were 2.5" but I'll check and let you know tomorrow.
  #37
Old 12-07-2016, 05:38 PM
Cee Jay's Avatar
People will say the exhaust is 2-1/4 inches, but it's in mm, 60mm, actually. 2-1/4" falls right near, 57.15mm. 2-1/2" = 63.5mm.
Since it's nigh unto impossible to get metric pipe in the states, the 2-1/4 will suffice. That's what my x-pipe is made from.
tberg (12-08-2016)
  #38
Old 12-07-2016, 06:27 PM
steve_k_xk's Avatar
Mine is 2.25
tberg (12-08-2016)
  #39
Old 12-28-2018, 12:41 AM
Ivelin Popov's Avatar
CORRECT SIZE for x pipe is 2
  #40
Old 12-28-2018, 01:54 AM
Received 4,458 Likes on 2,427 Posts
55mm OD actually
Cee Jay (12-28-2018)
