X100 XKR Owner Looking at early X150 XKRs
I've owned my 2000 XKR Convertible for 5 years, and my 1998 XJR Sedan for most of one year. I've had a great ownership experience with both. I'm a DIY girl from oil changes to engine and transmission rebuilds, and parts seem quite easy and inexpensive to get, and are pretty easy to work on.
I've been looking to replace the XKR with a newer car, and have been looking at early DB9 Volantes, and early X150 XKRs. I know the 5.0 SC cars are faster and have many nice changes, but I really think the early X150s are great value and they interest me a lot. They're basically as fast as the DB9 (and somewhat faster in some areas), but better fuel economy, more reasonable parts prices, and relatively easy to work on. I like that a nice XKR can be had for 50-60% of the same year DB9.
I know about the AC drain issue, but what other caveats are there? What are common problems? What should I be looking out for?
These cars are very reliable and handle beatiifully.
Some other things to watch for though:
-The leather delaminating from the dashboard, especially near the windshield.
-The rear window glass beginning to separate from the canvas convertible top
-The plastic thermostat hosing assembly cracking and needing replacement every 8-10 years, just as on the XK8s.
Ok, so far no huge issues. I'd buy knowing that I'd need to right away basically change the thermostat housing and keep 4k around for when I pull the dash to get retrimmed and to replace the top at the local hot rod upholstery shop (i used to run with an old school hot rod group, and this shop has done amazing, beautiful work). Definitely good to know this stuff though.
It does get annoying that they used a crap adhesive and have as little extra leather as possible this happens. I've seen this rippling on some Ferraris too.
Diligent and frequent use of leather conditioner (Lexol) and window shades when in the sun will prevent most dash problems. Poor wire routing in the front bumper can cause TPMS nuisance messages. The thermostats are NOT an issue on the supercharged version. The 07 has an 80's style power antenna, the 08's and later do not. I had the driver side cat go bad just before the warranty ran out. May be common, don't know. They don't like low voltage. Battery needs to be fresh and constantly tendered if not used often. I have a coupe so the rear windows generally separate. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
People will stare.
People will stare.
Aston parts are scary expensive, Jags less so - one of the reasons I decided to stick with Jags (though I don't do my own maintenance). Also, Astons are low-volume and, according to a mate who owned one, things tend to get changed from car to car, so there's sometimes no 'source of truth' on what parts to use and how they're connected. His was an older model, so the DB9 may be better, but it could make DIY work tricky...
If I had a nice pole barn I'd have quite the oddball collection. I just don't have the room right now for a car that's needy and a bit of work and time to get parts. I've seen the 2010s come down in price too, but it all boils down to this spring. I already have cash in hand but need to sell some cars to make room (I'm selling the Audis this fall and the XKR this spring).
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
jessejamestw23
09-26-2015 03:57 PM
