X150 Front Subframe
McJag222 (07-07-2024)
Eeeee...... I can't rightly remember. At least a few people in here have done this and say it's pretty straightforward.
Try this thread, or search for another...
https://www.jaguarforums.com/forum/x...bframe-258903/
I've now successfully completed the sub-frame conversion. It's not quite as straightforward as made out. Huge thanks to Paul at:
P C Auto's Jaguar Specialist, Aldridge, Nr Walsall for committing to, and completing this conversion.
Definitive XK X150 to F-Type Front Sub-Frame Replacement
- Locate an F-Type 3.0/5.0. The series one, RWD, Hydraulic Steering. The sub-frame is a direct fit. P/N EX53-5019-AH
- You will also need the rear lower control arms and headlamp auto height adjuster mountings and sensors.
- The lower control arms from the XK are too wide at the bushes, to fit the F-Type apertures. Replace with the correct F-Type lower (rear control arms inc. bushes). Luckily my sub-frame came with control arms.
- The lower front Banana control arms from the XK DO fit the F-Type Sub-frame perfectly.
- The headlight automatic height adjustment sensors and mounting plates are required from the F-Type sub-frame due to the mounting orientation being 90’ out.
- The original anti-roll/sway bar and steering rack fit the sub-frame perfectly.
- Keep the original XK headlight height sensors just in case the F-Type ones have a different connector. I had to retrofit my original R/H sensor.
- The Oil Cooler mounting tray will not fit the F-Type sub-frame, so discard. The oil cooler will screw into the sub-frame rear mounting hole and the front will slot under the retaining tongues. Fit a rubber bush between the cooler and tongues to prevent movement and rattling.
- Set the geometry as best by eye.
- You WILL require a full laser Castor, Camber, Toe/track check/set up.
The following 4 users liked this post by gizzmo77:
Daim
01-26-2017 01:13 PM
