X150 SC Replacing Secondary Air Injection vacuum hose
Hope you all had a good Christmas! Indulged in some engine bay cleaning during this break and I broke the SAI vacuum line, see attached. The thing was so brittle I managed to break it in 4 places, and I wasn't too rough, promise
It's the vacuum line which connects the secondary air injection vacuum tank to the rest of the circuit (marked in red in attached photo). I do very minor jobs on cars and never removed such a vacuum line, so apologies for the trivial question, but I'm really worried that given this line was so brittle, the other connected lines might also be, so I want to avoid any other major breakages.
How does the vacuum line disconnect from the three ends? Is it a matter of just pulling them out (gently) or do I need to be careful about something else?
Cheers guys and hope you have a good 2017!
I had a similar problem with the lines to the supercharger on my 2009 XKR (4.2) the thin brittle lines all cracked into pieces.
I replaced all of them with a clear tube from an auto parts supplier - I think it was windshield washer hose.
Fortunately there was enough left of the old tube which I cut down to around half inch in length to push the new tube over - the repair has been good for over six months.
Thanks, McJag222! That's very heartening. My temporary fix should serve well then. You seem to have tackled the hoses coming out from the supercharger, which seem to be a bugger to handle as they're quite into the engine crevices. I suppose you did not need to detach the old vacuum connectors, then? Did the hoses crumble through handling or did they just crack?
The one going to the back of the supercharger and the sensor is a bit fiddly - esp. the supercharger as its covered with insulating foil - I just pulled it up and through, got the connector off, and then fed it back down there and made the other connections after that
I just check every now and then to make sure the connectors are still attached to the new tubing.
I now run with the engine cover removed as it traps heat in there in my opinion. Some have questioned whether this would cause paint problems with the hood - not so far....
God knows how much of the car's plastic will flake off over time, McJag, so you do have a point about the crappy material used. To think that you could be in a fix somewhere in the middle of nowhere because of a dodgy part! Thought of removing the engine cover as well; the foam also flaked off, AND I didn't even touch it! I might check out the hood temperature with or without it, it would be interesting to see.
