xf will only start with smart key inserted
Old 08-03-2017 | 08:05 AM
AnneG's Avatar
Default xf will only start with smart key inserted
I have a low battery I believe. now it will only start with the smart key inserted
Old 08-03-2017 | 09:35 AM
Ranchero50's Avatar
The XK's use a CR2032 3v. I assume the XF is the same.
Old 08-03-2017 | 10:58 AM
Rey's Avatar
Rey
Confirm it is a CR2032. It is very sensitive to battery voltage. I have found Duracell "Duralock" to work well. Available at Walgreens.
Old 08-03-2017 | 11:28 AM
Cee Jay's Avatar
AnneG, I think maybe you should remove your entire home address from your profile and approximate it instead. Loonies could be about!
AnneG (08-03-2017)
Old 08-03-2017 | 01:02 PM
AnneG's Avatar
Thanks for that. I will do so immediately
Anne
Old 08-03-2017 | 10:45 PM
ralphwg's Avatar
One other thing Anne. There are a set of threads dedicated to the XF. For further issues with your car you will get better responses there.
Old 08-05-2017 | 11:25 AM
PsiFox's Avatar
Hi AnneG.
I'm a member of another new forum that covers the whole JLR group
Home | JagChat.
You should have a look there are lots of Xf owners. You can also sign up to the group attending the Jaguars at the Castle event at Warwick Castle in September. A great day out for all the family not just Car nuts.
marcoxpolo
11-20-2016 02:45 PM
marcoxpolo
11-18-2016 07:51 PM
Drossvet
10-21-2016 09:27 AM
julio1
06-11-2008 04:48 AM
01-16-2006 09:09 AM
Quick Reply: xf will only start with smart key inserted
