XK 2015 - Invery BlueTooth Hack
Hey everyone,
I just purchased an Invery BlueTooth accessory kit for my XK 2015. It fits the iPod jack fine, and is successfully transmitting audio via BlueTooth from my phone through the iPod channel. However, the only catch is that only the passenger side speaker is playing (and the center speaker + passenger speaker if on 3-ch mode). Does anyone have any advice about how to fix this glitch? All speakers are fully functional when playing the radio/CD sources.
Thanks in advance for your advice
I wasn’t aware Jaguar sold a BlueTooth adapter? If you could send me a link that would be greatly appreciated. (Just to clarify, the objective is to be able to play music from my Spotify app on my iPhone via BlueTooth).
Link below (purchased through Amazon)
Wireless Bluetooth Car Adaptor Music Interface for Range Rover, Land Rover, Jaguar in car i-Pod Integration (with i-Pod Cable)
Jaguar don't sell a BlueTooth adapter for music. MarkyUK was asking about the lead because you most likely either have a faulty lead or BlueTooth device.
The device you have bought looks like a clone of the Bovee 1000 which is what a lot of people, including me, use to stream music.
MarkyUK (06-21-2020)
Thanks everyone. The problem appears to be a temporary issue that resolves itself. For anyone experiencing similar symptoms in future, I’ve outlined a few important observations below:
- All symptoms disappeared the next time I started the car the following day. The Invery device streamed perfectly, and all speakers are now operating including the driver’s side speaker.
- That same day, a Bovee device I had ordered as a back-up arrived, so I thought I’d test it out of curiosity. Upon disconnecting the Invery and connecting the Bovee, exactly the same symptoms reappeared. In an attempt to resolve the issue I reconnected the Invery, and the problem persisted. After several attempts, the result was the same across both devices, so I left the Invery connected over night to see if it would resolve itself again. The next day, everything worked perfectly and there hasn’t been an issue since. (The car has been stopped and started 5 times throughout the day and it perfectly connects, streams, and plays through all speakers).
I will update this thread if any issues occur again in future.
Hopefully this is technical a glitch with my specific vehicle, but thought I’d outline the experience in case it’s helps anyone else out there.
Having same issue with Invery Bluetooth only has sound on the right side. I did everything from searches, ie went in to my iPhone and checked assessablity mono etc .. all is set up correct. It’s been 2 days and so far hasn’t changed like the OP which I wish it did. May return it to Amazon but if there is a fix that be great.
I just got it from Amazon, it pairs and shows the songs etc. Can control the songs from the steering wheel and volume.. my iPhone also pairs with my car too for calls etc.
it just plays the music only from the right side. It’s so frustrating as it’s so close to being perfect. I had a Bovee in my 09 BMW m3 and it worked perfect. Amazon Canada only has the invery so perhaps it’s just a cheap version of the bovee 1000. It just seems like I need one setting changed or something ? My Xkr is a 09 has the iPhone connector in the Center storage. I’m hoping some how it just starts to play correctly.
Re your problem, I would suspect the adapter cable between the iPod socket and the device.
My only reason for the thought is this: I currently have an actual iPod in my car. When I decided to do this I ordered a 'clone' cable on line, before I noticed a used genuine Jaguar one on eBay - and I bought that too. The genuine Jag cable and the clapped out old iPod work perfectly together. The clone adapter did not, and went in the bin.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
