XK 30K mile dealer service - check out the oil!
#61
its all pretty straight forward till you get into decarb and fuel injection service. think this is fun. I really enjoy getting quotes for dental teeth whitening $450-700. then posting on their webpages or dental forums about Amazon pro whitening gels and diy trays you can make to apply for less than $50.
Septic system for $8500? Damn I can buy the tanks, pumps and lines, rent a back hoe and install for less than $2500.
CPA to do my business taxes for $800! Please bitch I can do my own with TurboTax for $75 and have for the past 20 years.
**** I wired and plumbed my shop AND erected it saving more than $20,000 and the building inspector I know came by and said it looked great and I did a professional job. (Im not licensed but not live in the city) Why spend any money with any professional when between Google, youtube and forums I can learn and do anything....
These topics always crack me up, you would think anyone here could be replaced by either a robot or laptop and a afternoon of learning.
#62
I think the dealers for many makes in the SW USA recommend fuel injector cleaning because of the god-awful petrol we get here. You cannot get 93 octane anywhere I've been in CA, AZ, NV and UT and the climate is such the stuff is degrading quickly just because of the heat. Oh, and in places that are properly in the desert you just cannot stop the fine dust from getting into everything. It's insidious.
#63
Received 2,263 Likes
The quality of your gas is no worse than anywhere else.
Fuel octane has nothing to do with quantity or quality of additives.
Your car achieves full performance on 91 AKI octane. Anything higher is pure waste.
High octane gas does not deteriorate any slower or faster than low octane.
Airborne dust has no effect on clogging injectors or engines.
Your dealer sell injector cleaning and other non Jag recommended procedures because of the high profit margin.
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
#65
Soooo...... I have to say I do like these guys at Rusnak. They messed up some hose and Eden, my service rep, called and 'fessed up right away. Their bad. They will fix. BUT.... this particular hose (somehow linked to the supercharger) has to be shipped from coventry. Car now not available til Monday.
So I am now giving an extended road test to the brand spankin' new XE with the supercharged 6cyl that they loaned me, with their apologies. I'm not a small 4-door guy, but I'm liking it so far.
I'll keep everyone posted....
#66
#67
Shell V-Nitro additive package is only available in their premium octane- at least in USA.
And early test have shown it to perform as promised.
PRODUCT: Shell V-Power Nitro+ Test
#68
#69
Ironically there is some half-truth there.
davchr (05-05-2017)
#70
#71
Turbo's spool on heat, not flow. Higher BTU fuel nets more turbine speed and boost, look at diesels. Ethanol based fuels have less BTU per pound vs. conventional stuff. Part of the myth that corn is better than dino but it doesn't give as much energy so you burn more for the same power and lose economy on cars that aren't tuned specifically for low BTU fuels.
#72
The more I read the linked article, the more I'm convinced that it's joke. I think I'll stop.
#73
#74
Ranchero,
After the waste gate opens heat, speed, flow, etc do NOTHING to give "more turbo boost". The waste gate MUST be changed before the boost can be increased. Only then could you see "more turbo boost" from a higher BTU fuel.
MAYBE the RATE of turbo boost increase will be greater with higher BTU fuels. There is no way "Our (unscientific, but none-the-less user-based, and hopefully useful) consumer tests..." can show that. In any event, the maximum turbo boost is controlled by the waste gate, not the fuel.
I don't understand what you mean when you say turbo's spool on heat, not flow. If there is no flow through a turbine it will not turn, no matter how hot it gets. But that is a different discussion where we get into Boyle, Bernoulli, and Charles.
#75
[QUOTE=Mikey;1676628]True, but octane rating has no connection to the energy content of a given fuel.
A higher octane rating allows the engine to run a larger compression ratio, which puts more fuel and air into each cylinder each time it fires. You are not getting more energy from the fuel, you are putting in more fuel.
#76
Do some high octane fuels contain more/better additives than some low octane fuels? Probably, if you looked hard enough.
It's also probable that some high octane fuels contain more/better additives than other high octane fuels. That's what the top tier marketing scheme promotes.
It's significant to note that neither Jaguar nor their past and present owners, Ford and Tata, endorse the top tier scheme at all. Practical experience indicates that our engines are not picky about additives- unlike some other brands. Yes Audi, I'm looking at you.
Why would a high performance engine inherently need more/better additives than a low performance engine? If we are to take the Otto cycle in it's purest definition, the less efficient low compression engine should be more prone to contamination.
#77
The message is that the octane rating of a fuel is simply a measure of resistance to detonation- and nothing else.
Cee Jay (05-05-2017)
#78
Shell's best additive package is ONLY available on their premium octane gasoline.
So your gross general statement that higher octane fuels dont contain different additives is just plainly wrong and bad advice.
P.s. Shell is top 5 in this country.
#79
Ranchero,
To derive 1lb of boost from cold air would cost over 1lb of drag on the exhaust- thus intake. So a zero sum gain.
You can run hotter and derive more energy with more complete combustion.
You are not increasing boost over the design capabilities- just not depriving it.
#80
