XK 4.2 V8 Cutting out at idle
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I wondered if this is a common fault by any chance? The car is started, and then intermittently cutting out. Sometimes it's fine, other times it'll cut out several times before it can be driven off in D. Once driving it seems fine, so I'm thinking air/fuel mixture or perhaps an electrical fault with the push-button starter etc?
The car is a 2005/6 XK 4.2 Coupe.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
This hasn't happened with my XK but has on my Rover. I believe it's your throttle body is dirty. If it happens more when it's cold then it's probably that. It gets a gunk on there that's sticky. When it's cold it sticks more but once it warms up there isn't usually as much sticking. Mine would sometimes die at a stop sign for what appeared to be no reason. Very easy to clean.
Yeah it's done a lot of town driving in the past few months which I guess wouldn't help. I'll get back to the thread once I know what it is, but hopefully it's along those lines, thanks :-)
