The standard XKR back box has a different part number, I just didn't expand that section to save confusion but it looks like it had the opposite effect
Unless you have changed the backbox on your '10 you don't have the PAE. The standard XKR system is just know as the active exhaust system, as opposed to the semi active on the XK.
Dunno, man. I have PAE, but my box isn't the same as the R-S box either.
I'll look around, see if I can find those pictures I spoke of...
I didn't find the pictures I thought I saved, but I found the thread!
What makes you think you have PAE and not a standard XKR back box?
What makes you think I DON'T???
P(erformance) A(ctive) E(exhaust), or PAE, uses an ACTIVE (see the "A" there?) system that is controlled electronically and actuated with a vacuum to open and close ACTIVE valves on the exhaust system.
Well, heck-almighty, that's what I have! Remarkable, isn't it?
Oh, and besides, it's also on the Build Sheet.
Isn't the simple answer is to look under the car and if you have the X pipe and no resonators and the vacuum units on the back box then you have the PAE . Anything else is just the passive sport exhaust.
Originally Posted by jagtoes
Interesting as I have never seen the 530 number in any Jaguar information. where did you see this printed .
Originally Posted by u102768
This is from the official press release:
The metric equivalent of a single horsepower, referred to as 1 PS, equals 4,500 kilogram-metres per minute, which rounds to 32,550 foot-pounds per minute, or 0.9863 of a horsepower. https://www.autoexpress.co.uk/car-ne...d-ps-explained
The standard XKR backbox has vacuum units too. The standard XKR backbox and PAE are not the same thing, the internals are different.
My '10 has an X pipe but I added it so that is not a good test
Okay, so maybe I'm an idiot and only have the ACTIVE part, although I (now) have a resonator delete with X-pipe. "Standard" XKR box also. BUT BUT BUT, that post above says XKR boxes are all the same Part Number anyway, so that would make mine PAE regardless.
This is my non-PAE one. I hadn't noticed before, probably because they are always dirty, but the outer pipes are a smaller diameter whereas yours seem to be a similar size.
[QUOTE=kj07xk;1581767]Oh yeah! Not only gives the cat a nice pur under normal driving, you get a real braaap when you punch it, and the quad tips just look so much better than the dual tips (in my opinion).
And if you use the 'sport mode', those throttle blips on the downshift are much more pronounced.[/QUOTE.
Another option is to cut off the two valves on the XK muffler and then pull the valve stem out to the open position. You can then ether use a snap ring to hold them open or tack weld the stem to hold them open.
The sound is wonderful and the cost is $0.00. I have been running my 2007 XK for 103,000 miles with this setup. I am planning on removing the mid pipe resonator and replacing it with a “X-Pipe” or a “H-Pipe”.
I drilled out the valves on my 5.0 XK, happy with the results,
the semiactive exhaust actually releases gases from the sides of the
box when you go past 3500rpm.. now its open all the time.
Maybe not for everyone but worked quite well, not too loud also.
I realize this is an old thread has anyone else drilled out there pressure valve and how did you do it?
