XK exhaust to XKR modification
Old 01-10-2021, 10:13 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Originally Posted by jagtoes
Interesting as I have never seen the 530 number in any Jaguar information. where did you see this printed .
This is from the official press release:
jagtoes (01-11-2021)
  #42
Old 01-11-2021, 10:55 AM
Cee Jay's Avatar
Received 5,430 Likes on 3,207 Posts
Originally Posted by u102768
The standard XKR back box has a different part number, I just didn't expand that section to save confusion but it looks like it had the opposite effect
Unless you have changed the backbox on your '10 you don't have the PAE. The standard XKR system is just know as the active exhaust system, as opposed to the semi active on the XK.
Dunno, man. I have PAE, but my box isn't the same as the R-S box either.
I'll look around, see if I can find those pictures I spoke of...
I didn't find the pictures I thought I saved, but I found the thread!
https://www.jaguarforums.com/forum/x...xhaust-192443/
jons (01-11-2021)
  #43
Old 01-11-2021, 04:54 PM
u102768's Avatar
What makes you think you have PAE and not a standard XKR back box?
  #44
Old 01-11-2021, 08:09 PM
Cee Jay's Avatar
What makes you think I DON'T???
P(erformance) A(ctive) E(exhaust), or PAE, uses an ACTIVE (see the "A" there?) system that is controlled electronically and actuated with a vacuum to open and close ACTIVE valves on the exhaust system.
Well, heck-almighty, that's what I have! Remarkable, isn't it?
Oh, and besides, it's also on the Build Sheet.
  #45
Old 01-11-2021, 08:54 PM
jagtoes's Avatar
Received 1,839 Likes on 1,233 Posts
Here is my 2012 PAE and the build sheet with the option listed.
  #46
Old 01-12-2021, 12:30 AM
u102768's Avatar
Because the PAE wasn't listed as a mainstream option until the 2012MY, when the XKR-S was introduced.
This is from the 2010 MY brochure and just mentions Quad Exhaust Tailpipes:
This is from the US ordering guide for the 2011 MY and shows just the standard (active) exhaust for the XKR:
This is from the 2012 MY XK Product Guide and is the first MY that PAE is mentioned in sales material:
And here it is in the 2012 MY US brochure:
As mentioned earlier, the XKR 75 pioneered the exhaust that became the PAE but this is how it was mentioned in the press release for the 75:
So what exactly does your build sheet say? Active Exhaust? The only active thing the build sheet for my 2010 XKR mentions is Active Headlamps.
MarkyUK (01-12-2021)
  #47
Old 01-12-2021, 07:02 AM
jagtoes's Avatar
Isn't the simple answer is to look under the car and if you have the X pipe and no resonators and the vacuum units on the back box then you have the PAE . Anything else is just the passive sport exhaust.
peterv8 (01-12-2021)
  #48
Old 01-12-2021, 01:39 PM
Xk646's Avatar
Are you satisfied with the x-pipe? Noise and engine?
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
  #49
Old 01-12-2021, 03:49 PM
Stuart S's Avatar
Received 6,320 Likes on 3,465 Posts
The metric equivalent of a single horsepower, referred to as 1 PS, equals 4,500 kilogram-metres per minute, which rounds to 32,550 foot-pounds per minute, or 0.9863 of a horsepower.
https://www.autoexpress.co.uk/car-ne...d-ps-explained
530 PS X 0.9863 = 523 HP
  #50
Old 01-12-2021, 04:55 PM
u102768's Avatar
The standard XKR backbox has vacuum units too. The standard XKR backbox and PAE are not the same thing, the internals are different.
My '10 has an X pipe but I added it so that is not a good test
  #51
Old 01-12-2021, 04:57 PM
u102768's Avatar
Yep, I know although the US Jaguar brochures do seem to quote HP = PS
  #52
Old 01-12-2021, 05:22 PM
steve_k_xk's Avatar
Received 1,551 Likes on 895 Posts
The only visual clue would be the difference in the tail pipes the PAE has slightly larger tips
  #53
Old 01-12-2021, 05:58 PM
jagtoes's Avatar
Never measured but here is mine.
  #54
Old 01-12-2021, 05:59 PM
Cee Jay's Avatar
Okay, so maybe I'm an idiot and only have the ACTIVE part, although I (now) have a resonator delete with X-pipe. "Standard" XKR box also. BUT BUT BUT, that post above says XKR boxes are all the same Part Number anyway, so that would make mine PAE regardless.
  #55
Old 01-12-2021, 10:21 PM
u102768's Avatar
Still no
As I mentioned above, I only expanded the PAE options in the parts list to show that the XKR 75, XKR-S and cars with PAE all had the same part.
This is the more complete list and your car would have left the factory with C2P15668 which has been superseded to C2P24867.
  #56
Old 01-12-2021, 10:48 PM
u102768's Avatar
This is my non-PAE one. I hadn't noticed before, probably because they are always dirty, but the outer pipes are a smaller diameter whereas yours seem to be a similar size.
Rough external diameter of outer pipes:
Rough external diameter of inner pipes:
  #57
Old 01-13-2021, 06:42 AM
jagtoes's Avatar
Yep both of mine were the same OD
u102768 (01-13-2021)
  #58
Old 03-22-2021, 10:56 AM
AtRo Racing Products's Avatar
[QUOTE=kj07xk;1581767]Oh yeah! Not only gives the cat a nice pur under normal driving, you get a real braaap when you punch it, and the quad tips just look so much better than the dual tips (in my opinion).
And if you use the 'sport mode', those throttle blips on the downshift are much more pronounced.[/QUOTE.
Another option is to cut off the two valves on the XK muffler and then pull the valve stem out to the open position. You can then ether use a snap ring to hold them open or tack weld the stem to hold them open.
The sound is wonderful and the cost is $0.00. I have been running my 2007 XK for 103,000 miles with this setup. I am planning on removing the mid pipe resonator and replacing it with a “X-Pipe” or a “H-Pipe”.
Cheers,
Robbie
kj07xk (03-23-2021)
  #59
Old 05-02-2023, 04:57 PM
dynamohm's Avatar
Originally Posted by tarokyama
I drilled out the valves on my 5.0 XK, happy with the results,
the semiactive exhaust actually releases gases from the sides of the
box when you go past 3500rpm.. now its open all the time.
Maybe not for everyone but worked quite well, not too loud also.
I realize this is an old thread has anyone else drilled out there pressure valve and how did you do it?
  #60
Old 06-10-2023, 07:44 AM
Brachacz's Avatar
Related question - would XKR-S exhaust (the whole thing) fit into 2009 5.0 XK?
I guess it would be the same story as with XKR one - I'd need a tune and "always open"?
I would also need an XKR valence? Or is that different too?
Quick Reply: XK exhaust to XKR modification
