XK mid-pipe on an XKR is win!
Old 03-31-2020, 11:36 AM
Cee Jay's Avatar
Received 5,431 Likes on 3,207 Posts
So, I take it this is minimal surgery, basically shortening the loop pipes on each side, as so;
Easy enough, and I assume the internal piping and ribs are baffled or otherwise slotted or something, which would make quite a difference.
Thank you again, sir.
  #82
Old 04-01-2020, 02:44 AM
Received 4,458 Likes on 2,427 Posts
Pictures work fine for me?
TexasTraveler (04-01-2020)
  #83
Old 04-01-2020, 07:14 AM
Sovejag13190's Avatar
It's good, and sound is important ? There is no difference with valves open and close ?
  #84
Old 04-01-2020, 11:17 AM
Cee Jay's Avatar
Or not??? Weird though, it only appears to be YOUR photos. Everyone else's appears normally (I.... guess???).
Yours also appear as broken links in the quote above. At least to ME they do.
Maybe I'll have to submit a Problem to Firefox.
  #85
Old 04-01-2020, 11:35 AM
kj07xk's Avatar
Received 2,012 Likes on 1,345 Posts
Pics look fine on my crapple iPhone Cee Jay, maybe you’ll have to get one.
Sean W (04-01-2020)
  #86
Old 04-01-2020, 12:26 PM
Cee Jay's Avatar
HAHAHAHAHAHAHAHAHHAAAAA!!!! *sigh* oh, that was a funny joke.
Seriously though, everything is great everywhere (including my Pixel 4) except Firefox on PC. And, only from Cambo.
I'll try messing with my AdBlock add-ons and such, see if I can figure it out.
Pics work great on the F150 forum I am on, and that is also an "Internet Brands" site, like this one.
Dunno, man.
  #87
Old 04-01-2020, 12:33 PM
Cee Jay's Avatar
But anyway, back to the back box;
Unless there is perforated tubing where the packing is located on the outer chambers (which I suspect), it'd be almost a straight-pipe (although bendy) with a small glass pack on each side (due to perforations and packing). After modding, that is. Most of the actual MUFFLER seems wasted with that bypass setup, since No Flow. That's fine with me, since evidently it works and sounds better.
SO, either I buy a TIG; learn to weld Stainless better with my MIG; or pay someone (ugh) to weld some stuff up.
............ Eventually........... after I build my shop and get a lift....
  #88
Old 04-01-2020, 06:22 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
Any idea if this bit has already been modified or was it like that when he opened the box up because it doesn't match the diagram?
If that is standard, any thoughts on why the two sides are different?
Cee Jay (04-01-2020)
  #89
Old 04-01-2020, 06:32 PM
That's how it was when he opened it up, 100% original.
I think the drawing was for a 4.2L, or it could be that the drawing was "simplified" to not give away secrets.
No idea why it's not the same on both sides, but that's how it is, in a 5.0L XKR anyhow...
The following 2 users liked this post by Cambo:
Cee Jay (04-01-2020), u102768 (04-03-2020)
  #90
Old 05-13-2024, 09:43 PM
Gino944's Avatar
Default And for the 4.2L ?
Originally Posted by u102768
The PAE came out after your car was built so you had the standard active exhaust (as opposed to the semi active exhaust on the XK).
The PAE had the same mid-section as the XKR-S (note the VIN):
And the same rear section:
Hi, there is a website to look on that or your work on a Jaguar dealer ? Can you check what differences and parts numbers are existing for the 4.2L ? I own one of the 200 XKR-S and I didn't know if the exhaust is different.. the car is more silent than the classic XKR.. or maybe have a problem with the valve block ^^
  #91
Old 05-13-2024, 10:00 PM
Gino944's Avatar
Default What about the 4.2?
I don't know what the 5 litre sounds like with no catalysts but I took both cats off my '07 4.2 litre XKR after one failed a couple of days before Xmas and it was obscenely loud. I had to get special resonators made up to replace the central ones to try and quieten it down plus get my tune changed to alter when the valves opened on the back box so that it only opened at high revs.
I also got sick and tired of the rotten egg and fuel smell that permeated my clothes after parking the car in the garage so put some high flow cats in place eventually.
It doesn't really do it justice but this is what it sounded like with no-cats:
http://youtube.com/watch?v=A7ESmQOceVU
[QUOTE=u102768;2210177]It is all in the workshop manual but these are the three different exhaust systems:
XK:
XKR:
XKR-S/PAE:
Is this still different on the 4.2L XKR and XK model? I have an 2008 XKR-S (one of 200 for european market) I didn't know if something is different.
ralphwg (05-14-2024)
  #92
Old 05-14-2024, 07:30 AM
Lothar52's Avatar
Very good!
Now if you remove that last remaining resonator and put a crossover in it's place (X-pipe or H-pipe) you will have the perfect exhaust.
I have from when spires offered exhausts… it is numero uno!!
Snide72
01-30-2023 07:49 PM
trkyam
01-08-2021 10:48 AM
Swisstone
11-12-2020 07:30 AM
multistrada74
07-15-2015 03:37 AM
flyc2c
10-16-2014 03:51 PM
Quick Reply: XK mid-pipe on an XKR is win!
