XK Portfolio Convertible 2010 - good deal??
Not certain about what I am about to say but, the XKR got an updated steering rack as well. Comparing it to my '08 XK it is a big improvement in steering precision. Not sure if the '10XK has the same steering?
Also, the XKR suspension is more performance oriented with less understeer and tighter handling.
For the /10 XK(R) there was a TSB bulletin that instructed to re-flash the ECU to prevent the total run-down of the battery. That happened with my XKR. Apparently, the infotainment system does not alway shuts down in its proper sequence and keeps drawing 1.6 amps, enough to drain the battery in 2 days. You need to see if the TSB had been done, if not it is a few minutes of update.
Some people reported that occasionally the touch screen locks up. Never happened to any of my 5 late Jaguars. Altogether they are quite reliable these days. Water pump is probably the most serious of issues on the 5.0. They may start leaking and need to be replaced. Has not happened to any of my Jags, thus far either. Knock on wood... :-) but, they're all under warranty :-).
For routine maintenance, any decent shop should do. There is not that much to it.
Should you walk away from a car with paintwork? Only you can decide, but it should give you some bargaining power if it was not mentioned on CarFax and you find it. Heavy hit or something like that I would move on though.
If you got resources for both body and mechanical, why not!
I just purchased a 7yr/55K miles warranty directly from the Jaguar dealer. It was their top warranty, covering nearly all components except wear items. I paid $3799 without any haggling. It is pro-rated, meaning that you get back monies for any unused portions of the warranty. Works out to be about $46/month for the length and well worth my piece of mind. Jaguar repairs can be very expensive!
I got the 6yr/60,000 miles warranty with $50 deductible and up to $50 a day for a rental car with tire/wheel damage (zero deductible) for $3781 (including sales tax). I purchased it 30 days before the end of the factory warranty. If you wait for the factory warranty to expire it is considerably more money. Yes it is pricey, but just one major repair can pay for it. I'm planning on using it for the water pump which is not a case of if but when. Although these cars are a big improvement in reliability from older models, they are still expensive to repair. Of course a warranty is a gamble and I hope I don't use it. I'd rather say I threw away the money than not having it and needing to replace a blown engine.
The prices of all extended warranties are based on only one thing, the odds are strongly in favor of the dealer making more money on selling you a warranty then he will ever make fixing your car. I prefer to keep the money in my pocket. The xk's in the past 6yrs have proven to be very reliable.
In my case, the Jag dealership offered me a warranty at $3,250 for 2 years, which didn't seem good value to me. The local Jag specialist offered me a new car warranty extension for 3 years for $1,650, which did.
Much as I love Jaguars, if it doesn't cost me that much in repairs from the ages of 4-7 years, I'll be pleasantly surprised. The fact that I take mine on the track occasionally also increases the chance that something may give.
The car in question is being purchased second-hand and may have some issues - or track days!
Each to their own!
Cheers,
Rob
Sure - the warranty is a form of insurance. The decision to choose a warranty comes down to your view of the probability of significant repair bills, the difference between the cost of cover vs. potential cost of the repair and the value you attribute to ‘peace of mind’.
- that are not known, plus the 2010 is the first of this engine, so none of us know what surprises may lay in store as it ages.
Each to their own!
Cheers,
Rob
Each to their own!
Cheers,
Rob
![Icon Twocents](https://www.jaguarforums.com/forum/images/smilies/icon_twocents.gif)
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
