XK Remote Top demo video !
#41
#43
--Start the engine. Because the battery was disconnected, the message 'APPLY FOOT AND PARK BRAKE' will be displayed when the ignition is first switched on. Depress the foot brake and apply the parking brake by pulling it upwards. This is required to reset the parking brake system after the battery disconnection. The parking brake should now function correctly.
--Reset the windows and anti-trap protection as follows:
Ensure that the doors are closed and, and the convertible roof is closed. Fully close the driver's window, then release the switch. Again pull the switch to close the window and just hold for two seconds. Open the driver's window fully and release the switch. Again press the switch to open the window and just hold for two seconds. Fully close the passenger's window, then release the switch. Again pull the switch to close the window and just hold for two seconds. Open the passenger's window fully and release the switch. Again press the switch to open the window and just hold for two seconds.
-Reset the clock to the correct time.
-Reset the seat memory positions (driver and passenger seats) if seat memory had been previously set.
#44
#45
I have just installed Steves ( Jag wrangler ) new remote top on my 08 XKR convertible. WOW. This is incredible and so easy to install. It is Quite the experience to stand back press a couple of buttons on the remote and watch it go thru. its procedure, its like watching a transformer on the movies. The top goes up /down the windows go up/down and the doors lock, the alarm activates and the side mirrows swing back, all this from the remote or the door lock, plus the one touch conv button on the Inside. I also installed the rear side window option this is a MUST. Imho.
As far as the installation. It is very simple If you can take the rear seat out you can wire it without any experience of wiring, you just have to take your time read the explicet instructions very carefully and you can't go wrong,
I received mine last thur lunch and in less than two hrs I was working the top with the remote ,I have not put the rear parts back as yet as i want to operate it a few times over the next week ,but no problems as yet. the only thing at first I found was you have to cycle it two or three times, to let the module learn the sequence.
This is the best mod that a person could put on a convertible.
STEVE YOU ARE A GENIUS . THANK YOU. and for all the many hrs and thought that have gone into this amazing project. We are so lucky to have members like yourself on this foram..Bernie
Mods. coud you tag this onto Steves video post. Thanks.
WhiteXKR (01-18-2014)
#46
#47
Was this the BETA TEST module or the full blown production model that will be sold to us other XK/XKR owners.
Did you have to remove the roll bar box?
Thanks for the update as it relieves a few concerns about DIY installation.
I am looking forward to getting this device.
#48
Bernie:
#49
Thanks for your feedback Bernie!
Bernie is the first Beta tester who has installed the upgrade on his own. The only difference is that the production units will benefit from any improvements or feedback that the Beta testers provide.
After doing several of these kinds of products, I have learned that the first few users provide extraordinarily valuable feedback. I then improve the instructions and the product as necessary based on this feedback so the final production purchasers have the best experience possible. That is the reason behind the Beta test program.
In exchange for their time, the Beta testers get a special discount and a free upgrade to the production version (if needed).
As I posted earlier...I still need two Beta testers with a Right Hand Drive vehicle (one 2006-2009, and one 2010+) to work with me so I can bring this product to the UK, Australia and other RHD countries.
PS: One minor point on the rollbar assembly...yes treat it with respect as Bernie mentions, but it does not need to be stored upright. The sensors that detect rollover that trigger it are elsewhere in the vehicle, not in the mechanism itself. The rollover sensors have no part whatsover in this installation.
sherbercars (01-18-2014)
#50
The following 2 users liked this post by richzak:
sherbercars (01-18-2014),
#51
I was fortunate to have a forum member do a video of the X100 (early XK8/R) installation when I brought that out in 2011. Perhaps one of the members here will eventually step forward and do one also.
#52
I've posted threads in UK Region and Australia / New Zealand Region bringing this to the attention of members in RHD locations:
UK: https://www.jaguarforums.com/forum/u...quired-110135/
A/NZ: https://www.jaguarforums.com/forum/a...quired-110136/
I'll close those threads when you've found your testers.
#53
#54
#55
Barring any unforseen issues, I am hoping to begin production shipments in February 2014, beginning with the folks who are on the waiting list in the order they have contacted me.
#56
With the SmartKey, a press of door lock or unlock immediately halts the top once it is in motion. A second press will allow it to continue or reverse.
With the One-touch feature on the console, a press in opposite direction immediately halts the top when it is in motion. A second press will allow it to continue or reverse.
The One-touch feature can also be disabled with a switch on the module, which is recommended if you have small children.
For the rear windows (when operated separately from the top), once in motion, any single press or pull of the passenger window button immediately halts the movement. It can then be restarted in either direction with 3 pulls or presses of the passenger window button.
jagtoes (01-18-2014)
#59
-Steve
#60
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Quick update:
Beta testing is going well and I still expect that Left Hand Drive (LHD) Remote Top kits will start shipping this month to wait list customers as planned.
I still need one more Beta tester volunteer with a '06-'08 model XK/XKR convertible Right Hand Drive vehicle in the UK, Australia, New Zealand or other RHD country.
Although the final product will not take special skills to install, I would prefer a Beta tester with a slightly technical orientation.
I will offer the Beta test volunteer a HUGE discount on the kit and free upgrades in exchange for a little time extra time.
Please send me a Private mail or contact me on my website contact page: http://www.thejagwrangler.com/contact-us.html if interested.
Also contact me if you want to get on the waiting list for the production model (LHD or RHD).
Thanks!
-Steve
Thanks!
-Steve
