XK top won't go down or up
My top isn’t working. My mechanic says that the switches in the top harness are shot. He’s been trying to find a salvage harness for months with no luck. New it costs $3000+. Anyone have an idea where to find one? Mine is a 2007 XK. Also isn’t there any easy way to work the top manually? It’s prime convertible weather in Florida.
If that does not work get another opinion from a Jaguar specialist. Your mechanic's description does not make much sense. A defective switch can be replaced individually. Why replace an entire wiring harness? It sounds like he is guessing.
+1
More information is needed to help. List the exact conditions and indications including if the engine is running while attempting to cycle it. Complete wire harness failure is more than far fetched as a cause IMHO. Another point, what were the conditions when the top stopped opperation?
I just recently had an issue where the top wouldn't go fully up or down, and not drive-able in those positions (and I'm heading to my new home in Florida tonight!). Turns out the issue was my battery voltage was a bit too low; put it on my C-Tek overnight and the next day, bam! I'm back in business and thinking about the sunshine state :-)
New battery solved it.
I think that I’m just going to give and go to my local Jag dealer to figure this out.
My battery is at 13.4. The rear windows work but nothing else. When I press the button to move the top up or down, there is no sound save for the windows. As far as trying to work the top manually, it only goes down partially then there’s resistance and yes, I did turn the “bolt” one full rotation counterclockwise on the pump.
95XJSconv
07-25-2014 02:16 PM
pu5hkar
05-26-2009 03:28 PM
