XK vs XKR...4.2 vs 5.0
By way of example quite a few S-Type R cars were reg'd in 2008 (or later) though actually built 2007. Inevitably they'd sat around which at least in my eyes just reduces their value.
The VIN and registration document in effect reveal stuff like the above.
Good advice thank you!
I like the look of this one, any thoughts? https://www.autotrader.co.uk/classif...01911294888726
1 owner all its life is promising. Mileage is nothing to worry about. It IS a 2006 model year car (the quaint radio antenna is the obvious giveaway) so you might be able to use that as a haggling point. Personally, I'd prefer much lighter coloured leather in a dark car like that (mine is Lunar Grey /Ivory for example) but that is just a personal preference.
I would check the service history carefully. You need to see Jaguar main dealer stamps and/or a respected independent specialist's stamps. IMO, a stamped service book is NOT a 'full service history' and I would want to see all the invoices too. Only the invoices tell you what work was actually carried out. Also, pretty much every enthusiast owner will have kept a file of everything ever done to the car with all the corresponding invoices. If the invoice file is missing, ask why. The dealer /garage which serviced the car (see the service book) should be able to give you photocopies of all the invoices (offer to pay them a little for their trouble, although IME they never want it). If the garage says it can't give you the invoice copies due to Data Protection Laws, then tell them to blank out the previous owner's details before copying the invoices: you are interested in the content of the invoices not the name and address of the previous owner.
Invoices can tell you a lot - way more than a set of service stamps. For example, I'd like to see that the gearbox oil has been changed on a car with that mileage. It is supposed to be sealed for life, but all those in the know say it is is recommended to change the oil at 50,000 miles or so. In fact, I'd like to see that all fluids have been changed recently too. These things don't show up on the x-thousand mile stamp in the book!
I would also check the interior very carefully, looking for rips, tears, scuffs, damage of any sort as this can be very expensive to rectify. In the UK it doesn't get hot enough to worry about the dash leather peeling away but check it carefully anyway. On these cars electrics are very, very critical. Check that *every* button and switch operates correctly. If some don't, get them to agree to fix it before you take delivery. IMO that is better than them reducing the price a little and letting you get it sorted, since it can often cost more than you had thought. You ideally want to see a battery that is no more than 2 years old as well. Battery problems cause a lot of issues with these cars as they are so computer intensive.
Other than that, all the things you'd look for in any used car - check bodywork for issues, accident damage etc. ASK if the car has ever been in an accident of any kind - a dealer is obliged by law to tell you (not so a private seller I think). Check the seat belts. In any serious collision the seat belt actuators will have fired and often this means replacing the belts rather than repairing them. For some reason, some dealers will use secondhand belts from a breaker's and they will be grubby and look 'worn'. Just use commonsense and remember what Ronnie Regan said: always trust, but verify. Good advice.
I'd go and look at this example. Even if you don't buy it, it will give you some experience of the cars and a reference point. People always say "don't buy the first car you see" and it's good advice, but if the first car you see is genuine and ticks all your boxes, why not buy it? I have bought 'first seen' more than once and have never regretted it. Just be careful. Remember you are getting a fairly 'exotic' car and while the X150 is a reliable car (as 80srule says earlier) they are not Kias, so they will cost more if and when they need attention.
Finally remember the Golden Rule with cars like these: if in doubt, any doubt, walk away. XKRs aren't scarce so there will always be plenty of others to look at.
The following 3 users liked this post by barnsie:
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
![](https://www.jaguarforums.com/forum/signaturepics/sigpic171814_2.gif)
bfarrell (01-22-2022)
If a car is first registered in 2006 in the UK then it would be listed as a 2006 car but it would still be a 2007 MY car.
This is the summary of the first production XK from Topix. Note its MY:
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/423x355/b00379a_c2872854d14dc60dc92509866491e82cc4c6fcae.jpg)
JagV8 (02-27-2020)
#28
b
AlexJag (01-22-2022)
