XK Won't Turn over - new owner crying for help!
Hi Folks,
New to this forum and hoping someone may have some words of wisdom for me. I purchased a 2009 XK convertible this past summer and drove it sparingly, but enough to have run into a problem with it starting on several occasions. I would drive, park the car on an errand, come out a few minutes later and when pressing the starter button get absolutely nothing. Fiddling around with it and repeating the effort several times it always fired up eventually but with no apparent rhyme or reason. Since the fall I have had it stored in my heated garage with a trickle charger on it. Went out today to fire her up a bit and nothing! Battery is fully charged, dash lights came on, headlights and taillights, but absolutely nothing from the starter. The I could not even get the system to shut down - lights remained on and I could not get the accessories or lights to turn off. After an hour or so of frustration I did the trunk contortionist thing and disconnected the battery (I know - I'm going to have to reset some stuff when I reconnect it.)
Does anyone have a clue for me? Greatly appreciate it, thanks.
Your symptoms are indeed the perfect symptoms of a battery either too low in charge (despite your statement that it is fully charged) or that fails the "load" test, meaning that it will not power the starter. The symptoms on these cars are often counter-intuitive -after all the lights went on - but they are the exact symptoms I experienced last year on a 2007 XK. A new and fully charged battery was the solution. Be aware that new batteries are almost never fully charged so make sure that any battery you purchase is charged *by you* before installation. Do not take the word of the battery store clerk!
By the way, the fact that you drove your XK "sparingly" since purchase virtually guarantees that the battery is the problem!
I went through this last week, you are just going to have to find a sequence that your car agrees to. Read your manual, I have not had to do, but there is a way to start that basically bypasses the start switch, something about depressing the brake and slowly applying the gas pedal. Look it up to make sure you get it right but it may work.
If after all this excellent advice you are getting nowhere then you need to get stored diagnostic codes and problem solve from there. SDD has a routine to verify if you are getting ignition authorization and if not what is preventing e.g. brake pressure, start signal, security authorization.
