XK XKR automatic transmission question
I have noticed that in D and S, the car always reverts to 1st gear at stand still.
Is this a correct observation? If so, wonder why it does so, no need, well at least in D, 2nd gear would suffice just fine, much smoother of the spot, and most likely more fuel efficient... Or I am wrong here??
amcdonal86 (11-11-2013)
Everyone with the exception of u102768 (and the OP) is wrong. Both D and S, when operated in the automatic mode, start in FIRST gear. It's sort of funny how many people have lambasted first gear as useless in manual mode, when in fact the car is using first gear on every start when it's in automatic mode!
When using the manual/paddle mode, coming to a stop (assuming you were in a gear higher than 1st) will only downshift into 1st gear if it is commanded to via the left paddle. Otherwise it will leave it in 2nd gear.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Just spoke with my dealer. And they confirm that the box always reverts to 1st gear, in both S and D, only stays in 2nd if you are in S and shifting manually..
Petty I think... would have been so much better had it chosen 2nd in D, just like the ZF box in the 996 and 997 does..
Well just another reason to use the paddles...
If you have a 5.0, you can engage Winter mode:
However, it also changes the power & torque settings for a given pedal position:
N.B. Winter mode is also informally known as 'chicken mode'
- useful when allowing someone to drive who's never experienced something as powerful as an XK before. It isn't available on the 4.2.
The TCM changes the shift maps for the JaguarDrive control mode selected. This changes the shift points providing early or late upshifts and downshifts. For example, on slippery surfaces in winter mode the transmission will select 2nd gear for starting from a standstill on a flat surface to minimize wheel slip.
The EMS varies the accelerator pedal maps to change the amount of torque per percentage of pedal travel. The EMS can also change the accelerator pedal response to control the allowed torque change relative to the speed of pedal travel.
Each driving mode uses a combination of operating parameters for each sub-system… if the mode is changed from normal or dynamic to winter, the driver will notice a reduction in torque and engine speed
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
Found this on the web
"Tiptronic was developed in conjunction by Porsche, ZF and Bosch. Porsche originated the idea, ZF made the gearbox and Bosch was responsible for the electronic control. Little had changed since its introduction :"
The Complete Story of Porsche 911
Might consider a TCM reflash and transmission oli change myself.
Car had semi harsh down changes between 2nd and 1st. But better now, but still not as smooth as I want it to be... Dealer saying that the transmission is getting use to my driving.. Well we will see....
99xk8guy
06-05-2023 06:28 AM
