XK / XKR Battery Overview and Replacement
#61
So when/if my battery runs flat - The time for ECU to 're-learn' my driving characteristics is much longer than 10-15 km .. typical 250-300 km before it run normal again..
Is there a Way / tool to re- program ECU after battery disconnect , so I Can skib re-learn mode ?
Btw I have a XKR 99’ with 2006 4.2 Block .
Robban59 (12-17-2021)
#63
i have recently disconnected my Walmart 3 year old Everstart Max for well over a week after deep charging it with a 10 amp charger and it's been on a CTEK maintainer for 4 days. My Voltage is well over 12.66 after taking it off the maintainer, so I'm good to go again. This is my first time I have disconnected the battery for this long a period of time. I'm ok with resetting my seat and radio settings and relearning my driving style. What I'm really concerned about it the automatic window slight lowering when opening and closing the doors. Are those settings affected as well and will they need to be reprogrammed?
#64
If that doesn't work, then you probably have a bad window regulator or an obstruction in that window track. Ask me how I know, from 2011:
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/980x1462/screenshot_20210526_083346_chrome_7162d677fe1de19b0c4917c41dae7cc64a1d0400.jpg)
https://www.jaguarforums.com/forum/x...bration-57518/
bocatrip (05-26-2021)
#65
#66
#67
If the battery is off for an extended period, you may lose your Learned Driving Style and your Long Term Fuel Trims. Those relearn by themselves, and is sometimes beneficial.
Don't worry about the Battery System, it will relearn the new battery in a short time. Course, if you DO have availability of a system to reset the BMS, it won't hurt.
juan gram (12-17-2021)
#69
ive got a problem with my XKR4.2 supercharged roof as will not operate due to message coming up hood open been told the battery is knackered and that’s the main problem also got told that there is a smaller battery in the motor somewhere but I can’t find it think the mechanic is having me over as says he don’t know where it is either have tried to manually drop the roof but only goes so far and stops don’t want to force it incase I break something asking all you experienced members if anyone knows why it’s doing this if I bought a brand new battery would this kinda help it out and is there a smaller second battery in her somewhere ????
thanks
howard hill
#70
Welcome to the forums Howard,
The vehicle only has one battery. Expected life is around five years and a failing or partially discharged battery is notorious for causing all kinds of weird electrical faults. However, an ill-informed mechanic can be even more of a problem.![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
I've never had a convertible and will leave it to members with this variant to advise on whether this issue is battery related, possible causes and solutions.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
This saves so much pain and time, thank you! the battery in the convertible 2007 XKR is now much easier to replace.
06-XJR
16
07-05-2016 11:13 AM
