XK XKR (coupe) custom fiberglass subwoofer enclosures
I would like to fit 2 subs or just one big one , with amp. my car ia a 07 xkr with factory system, which i would be leaving. I know nothing about fitting one of these, wiring etc. Would any one have a step by step guide to fitting. What is the best sub and amp combination.
Eric
powerhouse (10-06-2014)
Sublyminal To answer your question, I believe you know where the factory amp/sub, my answer is i havent a clue
not a clue of how to wire it up to factory radio, how stupid am i. If i had step by step and what needed no problem. Pity yur so far away wuld pay for unit like this if you couls supply.
Have to say the job you have done is first class ,real professional.
![Icon Really](https://www.jaguarforums.com/forum/images/smilies/icon_really.gif)
Here's an example of what you'll need to use once you get to the factory amp.
![](http://i586.photobucket.com/albums/ss301/sublyminal7/Unknown_zpsb863247d.jpeg)
![Name: 112466_zps7993738e.jpg
Size: 16.0 KB](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/156816d1501214171-xk-xkr-coupe-custom-fiberglass-subwoofer-enclosures-112466_zps7993738e.jpg)
powerhouse (10-07-2014)
#28
No problem I will PM you the full step by step. As far as cost of course it would be cheaper to use one sub if you build a custom box as the materials used would be half as much.
#30
Thanks again Sublyminal , saw this sub and amp on ebay, would like to fit something like this as it would look good at night too. How to go about it is another thing.
2 i look at are, what sub and amp would you recommend.
CAR AUDIO HIFI SYSTEM SUBWOOFER AMPLIFIER AMP 4000W SET TWIN BASS SPEAKER LIGHT | eBay
CAR SOUND SYSTEM SET 2 CHANNEL AMPLIFIER SUBWOOFER SUB AMP 1400W LED FX + WIRING | eBay
#31
#32
The "best" may very well be subjective, but I am partial to JL audio. Great sounding subs. Another great SQ sub in my opinion would be the Alpine Type R. I also left my system factory, but I am considering changing out the door speakers. But to answer your question you would need to but a line out converter to tap into your factory subwoofer signal. You could tap into any signal, but I think this is the best signal to tap into so that you could still control the subwoofer level of output on the factory radio in "settings". I believe you know where the factory amp/sub is. Just tap into that. Any other questions feel free to ask and I'm sure others here also have info to chime in and help you.
Eric
Eric
Nice work.
#33
so you have no issues with volume matching or SQ issues at all? Not saying you dont know what you are doing because you obviously do, very top notch work. I just have no faith in LOC's, and obviously while much more expensive it seems like an MS8 or similar processor would be a much better choice.
#34
bigdhenderson (10-08-2014)
#35
Sublyminal (10-08-2014)
#36
#37
Hi all, if one of you could pm me the instructions to fit an amp to my car I would appreciate it, I have a spare kicker amp in the garage that has high end/speaker inputs, I would like to add this to run the speakers which I plan upgrade as well as another to run a 8" sub in the boot. I have a 2006 xkr.
I have just joined by the way
Rob
Rob
#38
