XK/XKR - 'How To' / DIY Repair & Maintenance
The earlier XK8/XKR has long been a model where owners are "hands on" and a considerable body of knowledge has built up in that forum "stickies". The X150 has been out of production for more than eight years and is getting to a similar stage.
Information or links to be added to this first post as threads, procedures etc are identified and recommended. Please make suggestions by post or PM and we can start adding links with "thanks" to contributors.
Section headings are in alphabetical order:
INDEX
1. AIRCON
2. BODY
3. CONVERTIBLE TOP
4. ELECTRICAL
5. ENGINE
6. FUEL SYSTEM
7. HANDBOOKS
8. INTERIOR
9. KEY FOB / REMOTE
10. LIGHTING
11. MAINTENANCE
12. PHONE
13. SUSPENSION
14. TRANSMISSION
15. UPGRADES
16. TSB
17. VIN - DECODE
18. WHEELS
19. WORKSHOP MANUALS
Topics within each section heading are also arranged alphabetically.
1. AIRCON
A/C Compressor Rebuild:
https://www.jaguarforums.com/forum/x...emoval-170640/ (thanks to 1999XK8)
A/C Drain Duckbill repair:
Two methods are discussed on the forum
https://www.jaguarforums.com/forum/x...lution-149349/ (thanks to DpezXK8)
https://www.jaguarforums.com/forum/x...-doing-222930/ (thanks to No Quarter)
Cabin Air Filter:
https://www.jaguarforums.com/forum/x...choked-107605/ (GGG)
2. BODY
Exterior Door Handle - replacement:
https://www.jaguarforums.com/forum/x...cement-210597/ (GGG)
Fasteners:
https://www.jaguarforums.com/forum/x...teners-231387/ (thanks to ejjbee)
Fuel Filler Bowl - replacement:
https://www.jaguarforums.com/forum/x...cement-227451/ (GGG)
Fuel Filler Door - won't open:
https://www.jaguarforums.com/forum/x...t-open-241042/
3. CONVERTIBLE TOP
Rear Window - repair
https://www.jaguarforums.com/forum/x...p-97478/page6/ (thanks to Stuart S)
Convertible Roof Rattle - fixed
https://www.jaguarforums.com/forum/x...-fixed-273239/ (thanks to wymjym)
Convertible Top - Hydraulics System
https://www.jaguarforums.com/forum/x...system-261030/ (thanks to JagRag)
4. ELECTRICAL
Accessory Socket - Luggage Compartment:
https://www.jaguarforums.com/forum/x...t-xk-r-262367/ (thanks to Bill400)
Battery - BMS Reset/Reprogram, Wet to AGM Change:
https://www.jaguarforums.com/forum/x...change-241034/ (thanks to DGL)
Battery Charging Kit - for CTEK
https://www.jaguarforums.com/forum/x...0/#post2566868
Blower Motor Resistor Module repair:
https://www.jaguarforums.com/forum/x...e-%245-184627/ (thanks to LosRubios)
The Workshop Manuals & Electrical Guides are in a separate "sticky":
https://www.jaguarforums.com/forum/x...guides-215509/ (GGG)
5. ENGINE
AJ133 5.0 Litre V8 Engine - Technical Training:
http://www.mediafire.com/file/0y6551...V8JLR.pdf/file
Cooling System Service:
https://www.jaguarforums.com/forum/x...ervice-186165/ (thanks to Patrick Wong)
Cylinder Numbering:
A composite diagram from two separate illustrations in the Workshop Manual.
Engine Oil - Specification
The revised specification from 2018 is STJLR.03.5006 and Jaguar recommend Castrol EDGE Professional EC5 0W-20. There are countless threads and opinions on the topic of brand, viscosity and change frequency but this is what the manufacturer has to say:
The acronym MENA refers to Middle East & North Africa.
Engine Tear Down - 5.0 SC
https://www.jaguarforums.com/forum/x...n-5-0l-266167/ (thanks to JagRag)
Spark Plug - decode
https://www.jaguarforums.com/forum/x...1/#post2336279 (GGG)
Supercharger removal and injector removal - 4.2 SC:
https://www.jaguarforums.com/forum/x...advice-214658/(thanks to gkubrak)
(see post #53 for a summary of parts and steps)
Supercharger Oil Change - 5.0
https://www.jaguarforums.com/forum/x...change-221427/ (Thanks to George05)
Thermostat replacement - 4.2 XKR
https://www.jaguarforums.com/forum/x...0/#post2613681 (Thanks to ExKayRick)
Timing chain replacement - 4.2
https://www.jaguarforums.com/forum/x...9/#post2425727 (thanks to steve_k_xk)
Valley Hose Replacement - 4.2 SC
https://www.jaguarforums.com/forum/x...valley-134108/ (thanks to dsetter)
Water Pump Replacement - 4.2 NA
https://www.jaguarforums.com/forum/x...0/#post2587348 (thanks to panthera999)
Water Pump Replacement - 4.2 SC
https://www.jaguarforums.com/forum/x...emoval-227569/ (thanks to gkubrak)
6. FUEL SYSTEM
Fuel Filter:
https://www.jaguarforums.com/forum/x...filter-260142/
7. HANDBOOKS
Vehicle Literature Pack
Replacements for missing JLR handbooks are available from Elanders Ltd in the UK:
https://www.jaguarlandroverliteratur...e/Replacements
8. INTERIOR
Cigarette Lighter Replacement:
https://www.jaguarforums.com/forum/x...ighter-159336/
Defrost Vent - Upper Dash:
https://www.jaguarforums.com/forum/x...r-dash-195005/ (thanks to TexasTraveller)
Dash Removal:
https://www.jaguarforums.com/forum/x...sh-how-172398/ (thanks to ajzride)
Floppy Sun Visor repair:
https://www.jaguarforums.com/forum/x...or-fix-188691/ (thanks to michaelodonnell123)
Headliner Refurbishment:
https://www.jaguarforums.com/forum/x...2/#post2520485 (thanks to ExKayRick)
Overhead Console Repair:
https://www.jaguarforums.com/forum/x...8/#post2688163 (thanks to Old Radar)
Start Button - Disassembly and Cleaning (2006-2009):
How to clean and lubricate the button assembly
XK Start Button 2007-2009 - Jaguar Forums - Jaguar Enthusiasts Forum (thanks to Bill400)
Sun Visor dismantle/rebuild:
https://www.jaguarforums.com/forum/x...-visor-243817/ (thanks to Craniac)
Veneer Kit:
1. PDF download
http://www.mediafire.com/file/g1lvpy...r_Kit.pdf/file (GGG)
2. Graphics
https://www.jaguarforums.com/forum/x...-refit-244951/ (GGG)
9. KEY FOB / REMOTE
Programming (information starts at post #6)
https://www.jaguarforums.com/forum/x...ion%85-171095/ (thanks to U1026768 and Cambo)
10. LIGHTING
XK XKR rear fog light repair (2010 MY onwards)
https://www.jaguarforums.com/forum/x...nwards-263001/ (thanks to sbolinha)
2010 XK Tail Light Upgrade (thanks to georgekale)
https://www.jaguarforums.com/forum/x...pgrade-277414/
11. MAINTENANCE
Maintenance Check Sheets - Jaguar
https://www.jaguarforums.com/forum/x...1/#post2173730 (GGG)
Maintenance - Service Summary Spreadsheet
https://www.mediafire.com/file/0t0yn...tory.xlsx/file (GGG)
Service Indicator Reset
https://www.jaguarforums.com/forum/x...63/#post899539
Jaguar Special Tools:
https://www.jaguarforums.com/forum/g...-tools-187726/
Jacking the vehicle - axle stand points:
https://www.jaguarforums.com/forum/x...ts-xkr-187308/ (thanks to Sean W and Swisstone)
12. PHONE
Jaguar Connectivity Centre:
http://jaguar50.nextgen-technology.n...d=1&Culture=en (GGG)
Will my Smartphone connect with the Bluetooth in my Jaguar?
https://www.jaguarforums.com/forum/x...jaguar-152361/
13. SUSPENSION
Ball Joint Boot Replacement:
https://www.jaguarforums.com/forum/x...5/#post2241347 (thanks to GordoCatCar)
14. TRANSMISSION
ZF Gearbox Faults - root causes & troubleshooting:
https://www.jaguarforums.com/forum/x...ooting-191977/ (thanks to meirion1)
ZF 6HP26 20322431 Repair Manual:
http://www.mediafire.com/file/vvimta...anual.pdf/file (thanks to Sean W)
ZF6HP26 - Technicians Diagnostic Guide:
http://www.mediafire.com/file/o68fau...F26HP.pdf/file (thanks to Sean W)
ZF 6HP26 Transmission Fluid Flush DIY:
https://www.jaguarforums.com/forum/x...sh-diy-217150/ (thanks to Don B)
ZF 6HP26 Transmission Removal, Disassembly & Rebuild:
https://www.jaguarforums.com/forum/x...ebuild-227587/ (thanks to jackra_1)
ZF Transmission - Troubleshooting Guide:
http://www.mediafire.com/file/anc5s7...guide.pdf/file (thanks to Sean W)
15. UPGRADES
Audio/Speaker Upgrade:
https://www.jaguarforums.com/forum/x...gation-192487/ (thanks to Cambo)
Backup Camera, iPod, USB Retrofit:
https://www.jaguarforums.com/forum/x...08-xkr-198002/ (thanks to jahummer)
DAB retrofit:
https://www.jaguarforums.com/forum/x...?highlight=DAB (thanks to Cambo)
Gauges on the Touchscreen (replacement of HKS Camp2):
https://www.jaguarforums.com/forum/x...-camp2-175877/(thanks to Sean W)
GVIF Interface Install for adding Backup Camera/Gauges:
https://www.jaguarforums.com/forum/x...camera-179570/ (thanks to flyc2c)
OBD2 display in ashtray location:
https://www.jaguarforums.com/forum/x...cation-233044/ (thanks to Cabrio Bob)
Tesla Style Screen:
https://www.jaguarforums.com/forum/x...8/#post2353375 (thanks to Sean W, Luke Martin, Lodhogrider, peterV8)
16. TSB
http://www.mediafire.com/file/y8ocsa..._TSBs.pdf/file
Also available as an attachment in post #9 of this thread:
https://www.jaguarforums.com/forum/x...orried-266164/ (thanks to panthera999)
17. VIN - DECODE
X150 Vehicle Identification Numbering system:
18. WHEELS
Retrofit a spare wheel:
https://www.jaguarforums.com/forum/x...-brakes-67260/ (thanks to Stuart S)
TPMS:
Diagnostic Trouble Codes:
https://www.mediafire.com/file/inh9w..._List.pdf/file (GGG)
Pinpoint Tests:
https://www.mediafire.com/file/jpshf...Tests.pdf/file (GGG)
Wheel Stud Size:
https://www.jaguarforums.com/forum/x...d-size-245552/ (thanks to Chris Grierson)
INDEX
1. AIRCON
2. BODY
3. CONVERTIBLE TOP
4. ELECTRICAL
5. ENGINE
6. FUEL SYSTEM
7. HANDBOOKS
8. INTERIOR
9. KEY FOB / REMOTE
10. LIGHTING
11. MAINTENANCE
12. PHONE
13. SUSPENSION
14. TRANSMISSION
15. UPGRADES
16. TSB
17. VIN - DECODE
18. WHEELS
1. AIRCON
Cabin Air Filter:
2. BODY
Fasteners:
3. CONVERTIBLE TOP
4. ELECTRICAL
5. ENGINE
Cylinder Numbering:
Spark Plug - decode
6. FUEL SYSTEM
Fuel Filter:
7. HANDBOOKS
8. INTERIOR
Dash Removal:
Veneer Kit:
1. PDF download
2. Graphics
9. KEY FOB / REMOTE
10. LIGHTING
11. MAINTENANCE
12. PHONE
13. SUSPENSION
14. TRANSMISSION
15. UPGRADES
DAB retrofit:
Tesla Style Screen:
16. TSB
17. VIN - DECODE
18. WHEELS
TPMS:
Pinpoint Tests:
Wheel Stud Size:
The following 30 users liked this post by GGG:
3.6 dave (09-11-2021),
a100steaksauce (07-11-2020),
ArtyH55 (03-06-2021),
Bill400 (08-02-2022),
Chris77 (08-27-2021),
and 25 others liked this post.
