I was browsing my local used car dealerships and ran into what they have listed as a 2007 XK Coupe Base but after looking at the pictures and seeing the square shaped exhaust I'm unsure if this is a modified Coupe or an actual XK60.
It has low mileage and is selling at an acceptable 15k. If this is a real XK60 I believe that's a bargain but I am not knowledgeable enough to confirm that it's the real deal.
No it’s An early XK 4.2, 2006 MY. You can tell as it has the rear ariel. From 2007 onwards this was built into the rear spoiler. The xk60 was launched in 2008. https://www.testdriven.co.uk/new-jag...the-jaguar-xk/ So I think someone has retro fitted parts to make it look like an XK60
I hand not even noticed the rear ariel until you pointed it out. Yes, this confirms my suspicion that it is a retro fitted XK. Thanks for the help!
The error positions are indicated by ! in Suggested VIN. In the Possible values section, each pair of parenthesis indicate information about each error position in VIN . The Numeric value before the : indicates the position in error and the values after the : indicate the possible values that are allowed in this position Unused position(s): 4,8;
In this era, the new Model Year was introduced in the second half (usually September) of the Calendar Year so a 2007MY could have been produced in the last months of 2006.
