XKR 75 Vortex Wheels now available
Old 05-29-2014, 12:33 PM
Lothar52's Avatar
that alot to ship... WOWZA!!!
Old 05-29-2014, 12:43 PM
Ngarara's Avatar
Received 1,126 Likes on 797 Posts
Originally Posted by Lothar52
"These were fitted with tyres then removed" mean (What does that have to do with the price of tea in China)?
I read it as disclosure: makes it clear that the rims are used, i.e. have had tyres on them, but that they are not being sold with tyres.
Lothar52 (05-29-2014)
Old 05-29-2014, 06:20 PM
Lothar52's Avatar
I was reading on the XKEC boards that one could put vulcans on a non-vulcanized XKR ie plain black pack but there likely would need to be some sort of spacers added. Thats a little much for my pea-sized brain - Im out!!
Loth
Old 05-30-2014, 06:44 AM
Ngarara's Avatar
Well, as far as I'm aware, the rear axle on mine (and the R-S) is the same as on any 5.0 XKR, so Vortex or Vulcan rims should fit all 5.0 XKRs. You'd need spacers to fit them to any other XK models, since the 5.0 XKR has the e-diff which pushes things out a bit.
Old 06-21-2014, 11:36 PM
Stuart S's Avatar
Received 6,284 Likes on 3,449 Posts
Default Spacer Help Needed!
Originally Posted by Cambo351
... You can fit them to the earlier cars by using a spacer on the back axles to reduce the offset.
Can anyone tell me how thick the spacers would need to be for the new Vortex wheels to fit on the rear of my 2009 XKR with Alcon brakes? Both new and old wheels have the same diameter, bolt pattern, center bore, and front width and offset, but the rear offset and width are different. The fronts should fit with no spacers, but I'm not sure what size spacer I would need for the rears.
Existing Selena wheels: rear offset +31 and 10.0" wide
New Vortex wheels: rear offset +52 and 10.5" wide
Is it as simple as the difference between 52 and 31, namely 21mm? Or am I missing something due to the 1/2" greater width of the Vortex wheel?
Thanks in advance for your help.
Old 06-22-2014, 07:23 AM
jleuz1's Avatar
There is a set of Selena wheels on ebay US with the following specs:
--- Front Wheels ---
Diameter: 20"
Width: 8.5"
Bolt Pattern: 5x108
Offset: +49 mm
Finish: Shadow Chrome
--- Rear Wheels ---
Diameter: 20"
Width: 9.5"
Bolt Pattern: 5x108
Offset: +26 mm
The set of Vortex on ebay UK have the following specs:
Front - 9J x 20" 49 Offset
Rear - 10.5J x 20" 52 Offset
So,on the front, since the Vortex are 1/2" wider and have the same offset, the outer position would EXTEND 6mm out and the inner clearance would be 6mm LESS. This should be no problem and would give you a 6mm wider stance.
On the rear, since the Vortex are 1" wider and have a 26mm difference in offset, the outer position would be RETRACTED by 13mm and the inner clearance would be 39mm LESS.
So if you used 20 mm spacers on the rear you would be effectively changing the offset from 52mm to 32mm. This would result in EXTENDING the outer postion 7mm and the inner clearance would be 19mm less. This should be no problem and would give you a 7mm wider stance in the rear.
As long as they clear the calipers you should be good to go.
The following 2 users liked this post by jleuz1:
Panthro (02-14-2016), Stuart S (06-22-2014)
Old 06-22-2014, 09:03 AM
richzak's Avatar
Received 1,233 Likes on 789 Posts
Stuart:
The rear OEM Selena wheel is NOT a 10" wide wheel (it's 9.5) and your offset +31 is wrong also, (it's a +26mm).
You can pull the rear wheel and tire and the sizes are stamped inside the wheel, both width and offset.
I have sent you the OEM Selena sizes in previous emails. Jleuz1 has the correct sizes posted above.
I don't suggest using wheel spacers. With the Alcon calipers you may have to replace the lug bolts to a longer bolt when using some wheels other than the OEM Selena on these Alcons. I am sure that this was discussed at length when we were emailing back and forth ref aftermarket wheels.
  #28
Old 07-30-2014, 06:41 PM
Stuart S's Avatar
Originally Posted by jleuz1
... So,on the front, since the Vortex are 1/2" wider and have the same offset, the outer position would EXTEND 6mm out and the inner clearance would be 6mm LESS. This should be no problem and would give you a 6mm wider stance.
And that is the crux of the problem - is there any way to determine with certainty (calculate) if the fronts and rears will clear the calipers, short of actually trying to fit them on the car?
And will the existing lug nuts work safely with 20mm spacers? Am I right that I'll need hubcentric spacers?
Thanks again.
Stuart
Old 07-31-2014, 09:22 AM
jleuz1's Avatar
Here are the 20mm spacers that others have used:
H&R Wheel Spacers For Jaguar Cabrio 2007-up 20mm (4035633)
As you can see they come with their own lug bolts. One member said he didn't have to do anything to bolt them on as the Sentas had an indentation so that he didn't have to modify the bolts. Someone else said he had to shave a bit off of the bolts.
axr6 did this so you might want to PM him.
Because you are going to have an extra 6-7mm clearance from the hub with the wider rims, I would think that they would clear the Alcons but I guess the only way to find out would be to fit them. Sorry I can't be of more help.
Stuart S (07-31-2014)
  #30
Old 08-17-2014, 11:49 PM
Received 4,454 Likes on 2,426 Posts
  #31
Old 08-18-2014, 08:11 PM
Stuart S's Avatar
Already sold for $3,000 plus $220 shipping.
  #32
Old 08-18-2014, 08:35 PM
Well that was quick!
  #33
Old 02-06-2015, 08:07 PM
Here's a 2008 XKR-S rear that needs some repair http://www.ebay.co.uk/itm/1-x-Jaguar-20-Vortex-REAR-SILVER-Alloy-Wheel-Genuine-XK-XK8-XKR-XKR-S-RS-/161479950159 still not cheap at £213...
So there are actually just three different Vortex wheels for the XKR?
2008 XKR-S 4.2L, Silver sparkle finish
9Jx20" front, ET49, C2P17497
10.5Jx20" rear, ET31, C2P17498
2010 XKR-75 5.0L, diamond turned with dark grey
9Jx20" front, ET49, C2P21957
10.5Jx20" rear, ET52, C2P21958
2014 XKR/S 5.0L option, diamond turned with gloss black
9Jx20" front, ET49, C2P25174
10.5Jx20" rear, ET52, C2P25175
So could you paint one of the diamond turned wheels sparkle silver to match the 2008 XKR-S look?
The spokes seem to be flat on the silver ones...
  #34
Old 02-07-2015, 05:38 AM
Ngarara's Avatar
The 2008 wheels have a slightly more rounded edge on the spokes because they're just painted like the rest of the wheel. The diamond-turned ones have a sharper edge between the fronts & the sides because some of the metal has been cut away.
You could definitely paint the other wheels silver to create the 2008 look - you could either keep or paint the diamond-turned faces. The later fronts would fit a 4.2 XKR (not sure about the Alcon brake option, though), but the rears would need spacers.
  #35
Old 02-07-2015, 07:39 AM
Stuart S's Avatar
The 2008 XKR-S (4.2L) was equipped with Alcon brakes as standard equipment. Only 200 were made for the European market.
Vortex wheels from 2008 will fit US-spec XKRs with Alcon brakes (MY 2008 & 2009, 4.2L). Not sure if the later version for 5.0L XK/XKRs will fit.
  #36
Old 03-09-2015, 08:23 AM
Wow, two complete sets of 2008 XKR-S Vortex wheels, 2500 EUR a set....
Original Jaguar XKR-S Felgen 20" Vortex NEU XK XKR | eBay
H20boy
07-23-2021 09:39 PM
PMKimpton
08-03-2019 08:22 PM
FrickenJag
09-25-2016 08:00 PM
metalmarty
09-11-2015 07:05 AM
edtexas
09-05-2015 10:49 AM
Quick Reply: XKR 75 Vortex Wheels now available
