XKR heated rear window
Hi all. I recently became the proud owner of a 2008 XKR (I introduced myself earlier this week) and am keen to sort out a few minor niggles, the first of which is an inoperative heated rear window,
I was hoping it might just be the fuse, but this seems fine so my next thought is a failed relay. Does anyone know where this is located as I'd like to change it before I go see the garage.
Many thanks in advance.
Rich
Rich
Yes the mirrors run off the same relay and off different fuses so if your mirror heat is working, then it's a connector, fuse, or a break in the element itself/loss of ground. The fuse for the rear window is F23, blue yellow wire.
