XKR lurching on hard takeoff
Hello all, tried searching and not really finding a good match to my issue. I have a 2008 XKR with 94,000 miles on it. Had it about a year now and love the car. Here lately the car lurches and surges on hard acceleration from a stop like it was a standard and i low RPM dropped the clutch. seems to run fine after about 3rd gear. no knocking or clanking and the shifts are smooth up and down shifts. Any ideas?
Seen your post on the Brit forum, waste of time posting there to tell the truth unless you have battery problems. Your car is the same as the old x100 xkr . do a hard reset doing the following to reset the gearbox , first turn on ignition, Then press brake pedal hard and hold firm with your foot for over 30seconds, It resests the gearbox. I done that on my 11plate every 3-4 month to reset mine and it works
Thanks, I had tried the battery reset of disconnecting both terminals and touching the leads but had not heard of this reset. Any indication when it is successful? I just did it both ignition on but engine off and engine on and never got any indication of anything happening. Clocked my time to over 30 seconds each time then took a drive and unfortunately still happening.
thanks everyone, so headed up to the local Jag dealer and they do not touch anything over 10 years old unless they have been servicing it for a while. They did recommend an indy shop that specializes in Jaguars so I will reach out to that shop.
To add more detail i had it serviced at an indy shop that specializes in Euro cars about 5 months ago. oil and filter, fuel filter, and a complete trans service as Ralphwg described. while not as bad this was happening before that. Shop tried to say it was normal and just remind him at next oil change and he would check the supercharger. Haven't been back and the lunging/surging/lurching has gotten worse in the last month although on the drive today it didn't seem as dramatic as before trying the reset suggested by Goerge05. Maybe placebo and wishful thinking on my part...
A DEALER said they wouldn't touch an older car?!? Dang, what a worthless place. I'd not go to them again, ever. Bad business practice, that. Just as well, that's where most dealers make a bulk of their profits, service. They way overcharge for per-hour work.
If it were ME, I'd o a fluid change regardless. It's probably mucky goo at this point.
guy (05-23-2020)
Have you tried re-adapting the transmission?
it does amazing things . I accidentally reset transmission adaptations though my SDD it was horrible after that. Did the transmission adaptation and all is good as new!
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
Thanks everyone, yeah without codes it really is a crapshoot. Called JagMac in Dallas and he is going to try and fit me in next Wednesday to take a look. He said it sounds like the trans is either low or TCM needs refreshed, but will know more after seeing/driving her. Will give the gas pedal reset a try later today (with the tender hooked up) and see if any change. Car runs great as long as I don't act like Don Garlets at the light looking down the 1/4 mile stretch , but it is so much fun I really want it fixed...
Put an IR thermometer on your CATS. Start it up and let it get to operating temp, then point the thermometer at each CAT first the front of the CAT, then the back of it. Check one against the other. If one is running ridiculously hot, say above 1600 degrees v.s. the other you prolly have a blocked CAT. Normal op temp is 1200 -1600 degrees
If the outlet temp is running 200 degrees or more than the inlet, you're running rich in that bank. If the outlet is about 500 degrees hotter than the inlet, you have unburned fuel in that bank.
If one of the cats is running hot, like around 2000 degrees it's likely clogged. Easy checks while your waiting to visit the transmission man. Cost of an IR thermometer is about $20.
Bad cats don't always throw codes so nothing lost but time by doing this
Bluebeast, I see you sort of closed this out on the UK forum site but not quite. You indicated "Just got her back from Jag Mac and he verified the fluid levels and reset the TCM and she screams off the line again."
You left them with a question as to whether the fluid was actually low or not.
By Verifying the fluid level, do you mean it was fine and he just reflashed the TCM?
It's helpful to us and to future users when we close out threads. Please close this one out with the details.
jahummer (05-28-2020)
