XKR owners, pull fuse 19!
Old 08-12-2022, 04:43 AM
unders's Avatar
Originally Posted by paulgorringe
totally agree with the fact it sounds better at low RPM and when down shifting in sport mode.
I chose to fit a remote control for fuse 19 so I can choose when to have noisy and when to have it quiet such as on long motorway journeys.
Easy to do and came with 2 very small remotes, one of which I have mounted in the ashtray and the other in the armrest cubby hole.
The two best mods I ever did was to swap for XKR-s centre pipes (new from Jag) then leave the fuse. The XKR-s has the standard rear exhaust box so fits in 30 mins. Then the Supercharger wheel change.
Changes the whole car with a re map. Better fuel economy too with this. These engines are bullet proof, so no sleep lost.
  #182
Old 08-12-2022, 06:43 AM
bamaboy473's Avatar
I, too, am following down the path you've taken. Being really new to the cars, does a different center pipe increase sound or HP, or both? Tell us more about the wheel; what, from where, is it a DIY fit, or does the car need a tune in conjunction with the wheel. Again, is this for performance or HP gain?
  #183
Old 08-17-2022, 01:55 PM
ToysARs's Avatar
Does anyone have any concerns with removing the fuse permanently from electrical standpoint? Can it be considered fully safe? Also how would this impact the vacuum pump in the long term?
  #184
Old 08-17-2022, 02:53 PM
Cee Jay's Avatar
Received 5,336 Likes on 3,163 Posts
I've not had fuse 19 installed for maybe eight years. I DID put it in once to show my son some months ago how that worked and it operated perfectly well. It's out again.
guy (08-23-2022)
  #185
Old 08-17-2022, 08:45 PM
JackJohn's Avatar
Fuse 19 has been out of my car since May of 2015, no problems.
  #186
Old 08-18-2022, 03:44 AM
Stuart S's Avatar
Received 6,266 Likes on 3,441 Posts
+1 since 2013 and have never wanted to put it back in.
Note that the 4.2L XKR and 5.0L XKR exhausts don't sound the same. The 4.2L is higher pitched and less raspy than the 5.0L, and not offensively loud unless you mash the exhilarator pedal. Light gas pedal pressure sounds almost like fuse 19 is still in.
  #187
Old 08-18-2022, 10:19 PM
jahummer's Avatar
Received 2,353 Likes on 1,475 Posts
A centre crossover helps blend left and right exhaust manifolds and uneven firing orders. The resonators you've got do that already, the difference is the R-S is only a crossover and you've got the additional silencing. It's all acoustics and has minimal effect on performance without a full custom header back exhaust and tune.
  #188
Old 08-22-2022, 11:28 AM
8bit's Avatar
I removed Fuse 19 from my old 4.2 XKR the day after I collected it and didn't put it back until about the day before I traded it in, 5 and a bit years later. The system still worked, as far as I could tell.
  #189
Old 08-23-2022, 06:57 AM
guy's Avatar
guy
guy is offline
Received 1,099 Likes on 773 Posts
In addition to removing the fuse, try changing the exhaust tips as well. The sound can be tuned by changing the tips to perforated type.
  #190
Old 08-23-2022, 07:01 AM
bamaboy473's Avatar
Do you have any links or brand suggestions? Are the tips secured with screws, or spot-welded? (it's raining cats and dogs, so I can't go to the garage to look....)
  #191
Old 08-24-2022, 06:31 AM
guy's Avatar
guy
guy is offline
Its only water .
The factory tips are welded on. However, there are perforated inserts available…
SamtheSham
05-20-2019 08:07 AM
obwoodie
12-12-2015 10:01 PM
kicknhard
06-14-2014 10:32 PM
sherbercars
10-15-2013 09:33 PM
doowopfix
02-18-2013 05:27 PM
Quick Reply: XKR owners, pull fuse 19!
