XKR pads and rotors recommend
The following 2 users liked this post by Cee Jay:
CA Jag (04-05-2023),
mosesbotbol (04-06-2023)
For X150 Jaguars, there are two different forums with similar names.
To Google this Forum, you must use the plural prefix "Jaguar X150 Forums". If you use the singular "Jaguar X150 Forum" you will be directed to a different forum.
Ask me how I know.
CA Jag (04-07-2023)
The following 2 users liked this post by Kyle_rs:
CA Jag (04-07-2023),
When I replaced my rotors several years ago, I chose R1 Concepts Geomet drilled and slotted rotors, and besides being beautiful to look at, have been smooth as silk ever since I put them on. Picking up my car on Monday from having EBC Red pads installed for the first time, so I'll have a comment on those after I pick up the car on Monday and drive it for a few days.
2010 Jaguar XKR WBPN2-20006 Front and Rear R1 GEO-Carbon Series Brake Rotors | R1 Concepts
Thanks for the feedback. Based on checking old Jaguar Forum posts (and reading manufacturers info), ceramics (different degrees of hardness) look like the choice if you're looking for high performance in sharp corners, 3 digit speeds and possible track use. For me, it's going to be both reliable for casual use but also performance when pushing the car hard. Like so many other owners, cleaning dust off the wheels gets old so low dust is important. Semi metallic seems to be a good balance between performance and less dust but haven't made up my mind yet. Drilled and slotted look great (and better heat dissipation) but can't be turned. Look forward to your feedback after a few miles w/ EBC.
The 355mm starts 32mm and discard’s 30mm; the 326mm starts at 20mm and should be discarded at 18mm.
CA Jag (04-08-2023)
